08 Head Gasket - Kawasaki ZX-10R.net
post #1 of 9 Old 12-02-2008, 06:47 PM Thread Starter
347 tony's Avatar
08 Head Gasket
So i'm just wondering has anybody put a .45 or.50 in an 08 ZX10, and if so can you run with 91 octane? tks
347 tony is offline
post #2 of 9 Old 12-02-2008, 07:20 PM
Speed Freak
garth285's Avatar
I haven't heard anyone on here doing it yet but I'm sure you can run them no problem... I am running 13.5:1 pistons on high test. if you go from the stock 12.9:1 to say 13.3:1 you should be safe....
garth285 is offline
post #3 of 9 Old 12-02-2008, 07:24 PM Thread Starter
347 tony's Avatar
08 head gasket.
Ok tks, i'm hoping somebody with an 08 Chimes in as well. My pump gas here is only 91 i think you guys have 93.
347 tony is offline
post #4 of 9 Old 12-02-2008, 07:35 PM
Speed Freak
garth285's Avatar
yeah i have 93 here.... im sure someone will chime in....
garth285 is offline
post #5 of 9 Old 12-02-2008, 07:36 PM
spikespiegel's Avatar
Send a message via AIM to spikespiegel Send a message via Yahoo to spikespiegel
how much more power this result in?
spikespiegel is offline
post #6 of 9 Old 12-02-2008, 07:40 PM
Speed Freak
garth285's Avatar
if you put in a thinner gasket and degree stock cams or put a 04-07 exhaust cam in on exh side im sure you can pick up a few more hp... hard to say since i havent been inside one yet but I'm sure a good 5+ easy.... very easy
garth285 is offline
post #7 of 9 Old 12-03-2008, 08:04 PM Thread Starter
347 tony's Avatar
Where are the cam gears available to degree the stock cams Garth? I was under the impression you couldn't do it with stock cam gears.
347 tony is offline
post #8 of 9 Old 12-03-2008, 08:06 PM
Speed Freak
garth285's Avatar
no, you can, you unbolt the stock cam gears in their location and there's a slotted section you can move the bolts to.... you just have to mark the cams so you have your setting points when you install them...
garth285 is offline
post #9 of 9 Old 12-03-2008, 08:21 PM Thread Starter
347 tony's Avatar
Oh so they are slotted, that makes thing easier. any lift #s come to mind?
347 tony is offline
head gasket P/N. barnymb Performance and Tech 4 11-02-2006 07:38 AM
Need 3mm head gasket... on1whl Vendors deals 1 09-27-2006 06:58 PM
Need 3mm head gasket... on1whl Wanted: Buy or Trade 0 09-27-2006 05:28 AM
Cam and head gasket are in!!!! garth285 Performance and Tech 12 05-16-2006 02:01 AM
Head Gasket?????? SP8 Performance and Tech 13 10-26-2005 10:35 PM
