08 crank in a 04???? - Kawasaki ZX-10R.net
post #1 of 7 Old 12-15-2008, 09:52 AM Thread Starter
just wondering if an 08 crank will drop into an 04...?.....it is suppose to be 2 lb lighter .
inginekilla is offline
post #2 of 7 Old 12-15-2008, 10:12 AM
Speed Freak
garth285's Avatar
I dont think they will I think if you had an 06-07 it can. if anything get the crank lightened polished and balanced at falicon.... takes 2 lbs off and it gives it a nice oil cutting polish....
garth285 is offline
post #3 of 7 Old 12-15-2008, 12:34 PM Thread Starter
thanks garth for the quick response.iwasnt aware that the gen1 and gen 2 cranks are diffrent only the flywheel.oh well there goes that idea
post #4 of 7 Old 12-15-2008, 05:49 PM
sextaafondo's Avatar
I read somewhere that the 06/07 crank is 2lbs heavier than the 04/05.
That leaves the 08 crank weighing the same as the 04
sextaafondo is offline
post #5 of 7 Old 12-15-2008, 05:52 PM
Speed Freak
garth285's Avatar
ya know what I forgot about that, they did make the crank I think 7% heavier I read somewhere..... so i wonder if they weigh the same...
garth285 is offline
post #6 of 7 Old 12-15-2008, 06:25 PM
About close I think.
Anyway, the 08 crank weighs are repositioned giving the same inertial mass as the previous heavier 06/07 crank.
post #7 of 7 Old 12-15-2008, 06:29 PM
ZX-10R_Sinner's Avatar
Yeah, the 06/07 cranks were made heavier to handle the torqe/power easier and not want to wheelie so much, then in 08 they made the crank lighter, but remained the same rotational inertia. I say make that shit as light as possible and let her scream...
It should be the same as in bigger motors, such as V8's. A heavier crank/flywheel makes a much broader spread of torque and power where a lighter one might make more peak power and a more inconsistent curve. Now I'm not sure that was necessarily the truth, because dyno graphs were compared with "supposedly" stock bikes and the 04's power curve was much more favorable. It does not mean that the 06/07 is any slower, makes less power, or is any less of a threat. Just helps keep the wheel down and in certain instances will make the bike faster. All in the nature of a beast, and with that said there is no taming a ZX10R.
At its core, the Ninja ZX-10R is a motorcycle built for the accomplished rider who can fully appreciate its capabilities--whether put to the test at a racetrack, or merely the focus of bench-racing conversation. It is, by all standards, the embodiment of the ultimate superbike.
Member of The Elite - Growler Group
ZX-10R_Sinner is offline
06 crank problem ? drkramm Performance and Tech 122 08-17-2016 10:53 PM
bike won't crank, need help jbm45 ZX-6R & ZX-6RR Archives 4 05-19-2008 07:45 PM
03 636 Crank bearings.... KIRK_ADAMS ZX-6R & ZX-6RR Archives 3 07-06-2007 11:04 PM
crank pulley 10roller The Out House 4 07-01-2006 10:04 PM
Crank Call miykl The Out House 9 01-28-2005 05:52 PM
