08 Clutch spring upgrade? - Kawasaki ZX-10R.net
post #1 of 9 Old 11-26-2009, 09:15 PM Thread Starter
strkd50's Avatar
I plan on going to the strip quite a bit next season and wanted to get some opinions on giving a little more life to my clutch pack. Orient express has heavier springs available and Brocks has spacers for the same price. Or should I just be leaving it alone???
2012 ZX-14R
#228
strkd50 is offline
post #2 of 9 Old 11-26-2009, 09:58 PM
get you some valve springs from a Gsxr 1000 and swap out 3 of yours with them then put 1 or 2 washers behind each spring
J-N-M Motorsports home of the fastest ZX-10's
Da Flea is offline
post #3 of 9 Old 11-26-2009, 10:12 PM Thread Starter
strkd50's Avatar
How much stiffer are the Gsxr springs? and how thick of a washer?
2012 ZX-14R
#228
strkd50 is offline
post #4 of 9 Old 11-26-2009, 10:30 PM
the stock valve springs are alot stiffer then the clutch springs that come in it. and as for the washer we just throw some regular ones back there we never measure them to be honest . just go to lowes and find you some washers that will fit and throw them in !!!
Da Flea is offline
post #5 of 9 Old 11-26-2009, 11:05 PM Thread Starter
strkd50's Avatar
any other opinions out there?
2012 ZX-14R
#228
strkd50 is offline
post #6 of 9 Old 11-27-2009, 06:34 AM
Speed Freak
garth285's Avatar
you can get a set of barnette clutch springs for about 26 bucks shipped directly from them they make them in 75, 85, and 100 lbs. the 100's are pretty crazy I'm actually running 3 of the 100's and 3 stocks in mine. you dont want some quieerzuki parts in your bike now do ya>??
garth285 is offline
post #7 of 9 Old 11-27-2009, 08:25 AM
TENN10's Avatar
Images: 145
Not sure about the the 3rd gen 10's. Do they have 6 springs? Do the ZX6's still run 4 springs? If so, the 6R springs are probably heavier or at least slightly longer than the
10's. In 2000 I ran 3 of the 6R springs in my 12R and it was a good, low cost upgrade.
Might be worth looking into. Shouldn't be too hard to find out.
TENN10 is offline
post #8 of 9 Old 11-27-2009, 09:09 AM
T Double D
Ratfink's Avatar
Images: 9
the barnett stuff is working for me
2005 ZX10r
2009 Monster ZX14 brocked out
2009 SuperStreetBike Magazine Top Speed Challenge Winner ( on a zx10! )
Ratfink is offline
post #9 of 9 Old 11-27-2009, 09:56 AM Thread Starter
strkd50's Avatar
What stiffness of spring are you running? and how many?
2012 ZX-14R
#228
strkd50 is offline
clutch spring spacer size zx-sik-r Performance and Tech 9 11-01-2009 06:27 PM
Clutch Spring Torque Specs green blur Performance and Tech 1 10-21-2009 07:17 AM
Brocks Clutch Spring Spacers GoTITANIUM Performance and Tech 2 04-24-2008 07:44 PM
CRG Clutch Blk Clutch Lever & Lightech Gas Cap yehzx10r Vendors deals 2 09-25-2006 05:25 PM
slipper clutch & clutch plates... jarhead05 Performance and Tech 14 07-07-2005 03:13 AM
