???? 08 calipers fit 05 - Kawasaki ZX-10R.net
post #1 of 8 Old 11-16-2008, 09:52 AM Thread Starter
streetfighter's Avatar
Send a message via MSN to streetfighter
can someone tell me if the 2008 calipers will fit my 05 10r please
04 zx10r, orange the fast color
streetfighter is offline
post #2 of 8 Old 11-16-2008, 02:10 PM
Postwhore with an 04
bcm0018's Avatar
I honestly don't think anyone has tried it. If you have access to a cheap pair I would try it and see what happens, might just need a spacer or something like the 1000RR calibers. If you are just looking to upgrade you brakes I would go with zx-14 or 07/08 zx6r calibers because they bolt right up. Also Ervins has a thread about using the 1000RR/600RR calibers with only needing a spacer. I don't know the details but I think its a sticky.
bcm0018 is offline
post #3 of 8 Old 12-02-2008, 04:41 PM
What's wrong with the stock calipers? Won't some good lines and pads do the trick? Are you seriously racing at the front of the pack or just hard track days or canyon racing? Most stock bikes with some decent rubber are way over most riders head...except pro racers. AFM#674
AFM # 674
AFM 674 is offline
post #4 of 8 Old 12-02-2008, 04:48 PM
Retired post whore
Alien10's Avatar
I believe that I read the 08 calipers will work but they require the use of ZX-14 rotors?
Alien10 is offline
post #5 of 8 Old 12-02-2008, 04:52 PM
Retired post whore
Alien10's Avatar
You're kidding right? The stock set up on my 04 was terrible - the brake lever would pull almost to the grip under normal street use. Since converting to a full ZX-14 system I have no complaints - the braking performance is superior to the stock set up.
Alien10 is offline
post #6 of 8 Old 12-02-2008, 05:18 PM
Gun Owning Republican
Ervins's Avatar
Send a message via MSN to Ervins
+1...I have ridden a few bikes and the stock brake set up on the 06 10R was straight fucking garbage...Not doing the caliper swap is crazier IMO...No way would I have bought a 10R if I knew the brakes were such shit...Hell I was close to trading my 10R for a gixxer 1k until I did the 1000RR caliper swap.
Heck I did the FrenTubo lines, Vesrah RJLs, and Brembo 19x20 Billet and it was still shit...Better but shit...Then I did the 1000RR calipers and all is PERFECT now.
2006 ZX-10R SOLD, 2005 KX250F, and 2007 YZ85
and a Ton of Guns
I will never own a Honda again.
www.ema-usa.com
Motorcycle Parts and Accessories
Ervins is offline
post #7 of 8 Old 12-02-2008, 05:23 PM
ZX-10R_Sinner's Avatar
I'm pretty sure the 08's have 310mm rotors where 04-07 only use 300mm rotors. So maybe you could get the 08 rotors and machine 5mm off, or get the new rotors as well but you probably won't notice much of a difference.
At its core, the Ninja ZX-10R is a motorcycle built for the accomplished rider who can fully appreciate its capabilities--whether put to the test at a racetrack, or merely the focus of bench-racing conversation. It is, by all standards, the embodiment of the ultimate superbike.
Member of The Elite - Growler Group
ZX-10R_Sinner is offline
post #8 of 8 Old 12-04-2008, 12:28 PM
I've got 08 Tokicos on my 07, but I had to fit ZX14 discs to suit, you will notice a difference from the stock calipers.
Also, on a gen 1, you'll need a radial master cylinder to get the best effect, a 2005/06 636 C1H/C6F seem to have the best reputation for the outlay.
doug_uk is offline
For those looking for ZX-14 Calipers!!!! photodigm1 General Motorcycle Discussions 0 07-23-2008 08:32 AM
Will 08 calipers fit 07? BrandensDogs Performance and Tech 2 04-23-2008 02:45 PM
calipers Redneck Rocket Performance and Tech 3 12-20-2007 11:42 AM
WTB: ZX-14 Calipers ripper Wanted: Buy or Trade 10 11-27-2007 10:01 AM
Just won me some ZX-14 calipers!!! undrlord The Out House 21 08-10-2007 02:39 PM
