07 arm on 05 10r - Kawasaki ZX-10R.net
post #1 of 31 Old 01-19-2008, 05:58 PM Thread Starter
bodyglove's Avatar
Images: 15
Send a message via MSN to bodyglove
07 arm on 05 10r
ok today i bolted up an 07 arm on my 05 10r, well it bolts up perfectly every thing matches perfect , ok just have to use the 07 rearbrake bracket , every thing else is good
ID:	56325   Click image for larger version
bodyglove is offline
post #2 of 31 Old 01-19-2008, 06:01 PM
Retired post whore
Alien10's Avatar
Looks good. Does it handle any different with the new arm?
Alien10 is offline
post #3 of 31 Old 01-19-2008, 06:04 PM Thread Starter
bodyglove's Avatar
Images: 15
well its a little shorter i think because had to remove 1 link from chain so i gues it has a shorter wheel base now , but i have it just for looks , have a new arm on the way .
post #4 of 31 Old 01-19-2008, 09:17 PM
Send a message via AIM to 06hulk Send a message via Yahoo to 06hulk
hey you might want to put the support bracket on. it goes where the 06 pipes ran up to the back through the swingarm. its pretty thick plate so you might need it just for rigidity. looks sweet though
06hulk is offline
post #5 of 31 Old 01-20-2008, 01:07 PM Thread Starter
bodyglove's Avatar
Images: 15
ok about the plate , have to cut it because it hits on the exhaust where the valve is , so thats something that has to be done
post #6 of 31 Old 01-20-2008, 02:21 PM
Though it looks great I think you may run into some performance issues with it.
Even though the Gen1 and Gen2 frame look nearly identical from the outside they are quite different on the inside. Braces to stiffen some areas and lack of braces to add flex have been relocated from model to model. This all also comes into play with all chasis components to include the swingarm and suspension components.
Now granted the affects may not be enough that the average street rider could even pick up on them; or they may cause you some goofey ride characteristics.
Just keep note that with your swap out you may never get your front and or rear suspension to work smooth; as one affects the other. A one inch shorter wheelbase is a pretty big change also.
06450F is offline
post #7 of 31 Old 01-20-2008, 02:23 PM
What is going on with your fork tubes? Please don't tell me your lowered your front 3 inches?
06450F is offline
post #8 of 31 Old 01-20-2008, 02:25 PM
Wiz
Wiz's Avatar
Images: 19
Send a message via MSN to Wiz
would it not alter the way that the bike handles as I thought that the 07 model like the 06 had a different swingarm pivot position. I am sure that it had been moved higher up as to aid in the stability but hey if it bolts in and yuo haven't noticed any difference then all is great . Well done as it looks the business
Wiz is offline
post #9 of 31 Old 01-20-2008, 03:46 PM Thread Starter
bodyglove's Avatar
Images: 15
we dont dont have closed track here or any thing like that ,so i dont really worry about twisties, we just have drag strips , so i just did this because i like this arm better . my chromolyarm and sidewinder is on the way ,then install my cams , heavy duty springs and gasket , some headwork, ok about the swap the ridding height is the same no dif in height
and the dogbones everything line up perfectly and smooth,
ID:	56411   Click image for larger version
ID:	56412   Click image for larger version
ID:	56413   Click image for larger version
post #10 of 31 Old 01-20-2008, 05:03 PM
Speed Freak
garth285's Avatar
IF that arm was only lighter then the 04-05 arm it would be have been on my bike to. I dont know why there were claims of a light swingarm???? I dont know really but the 04-05 arm is about a pound lighter but I do like the looks of this 06 arm a lil....
good luck!
garth285 is offline
