07 to 04 Fork swap????? - Kawasaki ZX-10R.net
post #1 of 8 Old 08-30-2008, 11:37 AM Thread Starter
SP8
SP8's Avatar
Will the 07 fork tubes bolt right up to 2004 equipment?
SP8 is offline
post #2 of 8 Old 08-30-2008, 01:12 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
Yep I got them in my bike, they are about 10MM longer than the 04-05 forks, so adjust them in the triples for that if wanted.
9R to 10R is offline
post #3 of 8 Old 08-30-2008, 01:47 PM
sonic397's Avatar
Wow, that's interesting. Do you feel a big difference in the ride quality? Was it worth the swap?
How's the price : performance ratio?
05 Ninja ZX10r - Parting Out
sonic397 is offline
post #4 of 8 Old 08-30-2008, 02:02 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
The only reason I changed them is cause I have Ohlins on my 06, and had the extra set of 06 forks, and wanted to be able to swap my wheels (PVM and Carozzeria) wheels back and forth between the two bikes with no hasles.
post #5 of 8 Old 08-30-2008, 02:03 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
But they do seem a little bit bettter than the 04-05 forks, a little more compliant over the bumps, but I really have not played with setup that much.
post #6 of 8 Old 08-30-2008, 02:40 PM
Speed Freak
garth285's Avatar
I'm on a set of 06-07 forks on my 04 as well.... swapped them over to fit my 06-07 marchesinis....
garth285 is offline
post #7 of 8 Old 08-30-2008, 03:31 PM Thread Starter
SP8
SP8's Avatar
So the 04 wheel axel? Or do I have to change the wheel bearings? If so will the 07 bearings fit the 04 wheel? Obviously the fender will fit if you guys are using PVM wheels. One of my caliper bolts was cross threaded at the factory, and is now striped. I like the look of black fork bottoms. Ohlins tubes would be nice, but I like the look of the 07 all black more. So I'm thinking of getting those and having them reworked.
SP8 is offline
post #8 of 8 Old 08-30-2008, 03:33 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
NO, you will need a 06-09 and up front wheel and axle/spacers
Fork Spring Swap Help! lunitk Performance and Tech 1 05-28-2008 10:23 PM
should I swap to a 06-07 race tail along with my front end swap? garth285 The ZX-10R 10 12-05-2007 09:21 PM
04-05 rim swap... Rock_Star The ZX-10R 2 05-07-2007 02:55 PM
swap fmf for evo II jon0410R Performance and Tech 6 08-08-2006 10:46 AM
Fork Swap aren ZX-6R & ZX-6RR Archives 4 07-29-2006 09:23 PM
