06 zx10r fi light blinking - Kawasaki ZX-10R.net
post #1 of 13 Old 05-05-2011, 01:08 AM Thread Starter
hello all i just got an 06 zx10r it has 4k on it an Dual Akrapovic slip on exhaust and a pcIII the bike runs fine but that light is annoying and ive read if its blinking it could be in a limp mode which hinders performance any ideas? i appreciate all info thanks
ricanlinxzx10r is offline
post #2 of 13 Old 05-05-2011, 02:20 AM
Dont mess wit White Ninja
abzx10r's Avatar
take it to someone who can trip it into dealer mode then you can run the codes and find out the problem! good luck
abzx10r is offline
post #3 of 13 Old 05-05-2011, 03:57 AM
IIRC you can find instructions for dealer mode in the service manual
a.leopard is offline
post #4 of 13 Old 05-05-2011, 06:38 AM
filthy phil's Avatar
yo can pull the code yourself.
with the odometer displayed, you push and hold the mode button, iirc. the code comes up. likely code 63, the exhaust flapper thing. mine does it occasionally
team FTP
Area p, zx14 nissins and mc
Riflemans 1/5. -1 +1 sprockets w/chrome ek zzz. galfer lines. K&n.,ultra custom black front fender // over 55k miles
filthy phil is offline
post #5 of 13 Old 05-05-2011, 07:21 AM
BigCat for Prez!
BigCat10R's Avatar
if its the exhaust valve its code 34, mine had the same problem. if it is 34 go to servobuddy.com and thatll fix it
BigCat10R is offline
post #6 of 13 Old 05-05-2011, 09:15 AM
THECYKOTIK1's Avatar
Hold the reset button, get the code, do a search on this forum there is a thread somewhere that has all the codes listed in it.
Full Ti/CF Akrapovic EVO system, K&N filter, .045 Head gasket, Shaved & Ported head, Kawasaki race valve springs, Kawasaki race cams, PCIII + Ignition Module w/ rev extend, Removed secondary butterflies, Ivans TRE, PLX wideband, Orient Express clutch springs, Cut-down seat, Rifleman throttle insert, Muzzy links/Schnitz strap
THECYKOTIK1 is offline
post #7 of 13 Old 05-05-2011, 12:50 PM
BigCat for Prez!
BigCat10R's Avatar
gotta press mode till it shows ur odo b4 u hold down reset
post #8 of 13 Old 05-13-2011, 01:48 PM
im trying to pull my code too on an 08...is it the same process? do you do this with the engine running, or just the key turned? Thanks
2008 ZX-10R Candy Plasma Blue - Akrapovic Evo Full Ti System, PCV with Autotune and LCD Display, Scotts Damper, BMC Filter, Gilles VCR Rearsets, Brembo RCS 19 Master Cylinder, Galfer Superbike Brake Lines, Galfer Pads, zx6r rear seat cowl & rear hugger, Tapeworks Rim stripes, Shogun Frame & Axle Sliders, Pazzo Shorty Levers, SpeedoHealer, Greggs Customs Mirror Blockoffs, Graves Block Off Plates, Michelin Pilot Pures, -1 +1 520 Conversion
czacharyasz is offline
post #9 of 13 Old 05-13-2011, 03:12 PM
SkyDork's Avatar
Same process for the Gen 2's and 3's.
1) Turn the ignition on
2) Press 'mode' until the odometer is displayed
3) Press and hold 'reset' for 2 seconds or more
4) The 2 digit trouble code(s) will be displayed where the odometer display normally is
5) Turn the ignition off to return to normal display
#WordCrimes
SkyDork is offline
post #10 of 13 Old 04-28-2014, 03:48 PM
Smile No Code?
I have an 06ZX10R, FI light flashes when running. Do you shut down the engine but leave the key "ON" and do this? Otherwise I lose the code and it doesn't come back on until I hit higher speeds. I'm planning to try this technique tonight.
Thanks.
Andonon is offline
FI light blinking after X-tre install Help!! j1000 Performance and Tech 27 06-08-2013 04:53 PM
oil light blinking after oil change GODZFORCE General Motorcycle Discussions 13 10-21-2012 02:15 PM
blinking light???? normal jagerbom311 Performance and Tech 3 04-15-2010 10:54 PM
FI Light Blinking ninja japan Performance and Tech 10 05-07-2008 10:46 AM
red oil light blinking 10R-rugger Performance and Tech 8 02-09-2008 02:27 PM
