06 Mods and Dyno Results - Kawasaki ZX-10R.net
post #1 of 18 Old 03-11-2008, 03:51 PM Thread Starter
green_zx's Avatar
Send a message via AIM to green_zx
Well on Monday I made the trip to Schnitz Racing in Decatur, Indiana to have Ryan Schnitz tune my 06. From the results I got I am pleased and just need to "butt dyno" the results. First off a list of my mods
BMC Race Filter
Muzzy Block Off Plates
Arrow Slip-On Exhaust *Shortened*
Stock Mid-Pipe with Cat removed
Kawi Race Intake Cam *Stock Position*
Kawi Thin Head Gasket .50mm
PC3 USB
PC3 Ignition Module
Forgot to mention that this is on 93 octane pump gas.
Before I hit the dyno there were a few things I noticed.
1) The bike was rich down below 6k
2) It was really rich below 3k and would dog and sometimes stall on decel.
And the Results:
The First is the final run after the map
The second is the first initial run and the final run together
As you can see from the two runs together is that I did not rain a ton of power. I gained a few hp which is fine. The thing that interest me the most is the mid-range. if you look at the a/f comparisions there is where most of the change came in. He smoothed out the a/f throughout the mid-range. Hopefully this should get me more responsive power. That would be nice becasue this is a track bike. By the time he was done the bike did sound a lot "happier" as it wound up. One thing he did recommend and I did was the dynojet rev xtend. The code is in there and now I just need to ride it to see how it feels.
green_zx is offline
post #2 of 18 Old 03-11-2008, 03:58 PM
With the rev xtend installed what does the bike redline at? Can the bike handle the extended revs without stronger valve springs
Skip114 is offline
post #3 of 18 Old 03-11-2008, 04:19 PM Thread Starter
green_zx's Avatar
It should bump the actual redline to 13k. The tach is off about 800-1000 rpm. Yes the stock valve springs should handle the load.
green_zx is offline
post #4 of 18 Old 03-11-2008, 06:36 PM
dsabat's Avatar
Looks good, Ryan knows how to tune. Do you remember what the numbers were in SAE?
dsabat is offline
post #5 of 18 Old 03-11-2008, 06:40 PM
People get hung up on HP....IMO the air fuel mixture is way more important and everyone should have their bike on a dyno mods or not just to have it on paper your bike is running right
Titan10r is offline
post #6 of 18 Old 03-11-2008, 07:45 PM
Big Daddy's Avatar
Images: 38
exactly!! drivability and user friendleness is most important.
Big Daddy is offline
post #7 of 18 Old 03-11-2008, 07:52 PM
inappropriate
hesaves0211's Avatar
Images: 67
you shouldve removed the secondaries jk thats your personal preference. but the only reason i mention it is because you said your bike was running rich, the secondary mod leans it out a bit which couldve help in more way than one. do you feel a noticeable change in power delivery?
hesaves0211 is offline
post #8 of 18 Old 03-11-2008, 08:12 PM
axo250's Avatar
Send a message via AIM to axo250
Did Schnitz mess with the timing much? What kind of timing are you looking like in general? I haven't had a chance to tune my timing in since I got the module on so I have a generic +3 advance at the moment to play it safe. Also I'm assuming this was on race fuel since this is a track bike?
axo250 is offline
post #9 of 18 Old 03-11-2008, 08:16 PM
Shorty's Performance
madnessracing's Avatar
INDEED!! those are some great numbers man! i love the a/f band it's so smooth and perfect.
madnessracing is offline
post #10 of 18 Old 03-11-2008, 08:30 PM
dirt ninja's Avatar
Images: 9
Good#s and a/f...Just curious why you didnt degree the cams?
dirt ninja is offline
Dyno Results from My 06 ZXR JimmyJam Performance and Tech 10 07-04-2007 02:02 AM
Dyno Results flank31791 Performance and Tech 6 03-20-2007 04:20 PM
Fun with dyno results.... majin ssj eric The ZX-10R 2 03-11-2007 10:13 PM
07 R1 Dyno Results BigDally The Out House 14 01-17-2007 08:59 PM
dyno results scottymizt The ZX-10R 14 07-07-2004 08:07 PM
