06 damper install on an 05 - Kawasaki ZX-10R.net
post #1 of 14 Old 01-30-2010, 10:26 PM Thread Starter
BozZX10's Avatar
I picked up a stock 06 damper from a friend and thought Id post some pics of how I installed it.
First I bolted it on to the frame at the front of the tank.
Made a tab to attach to the top clamp
Made a jam nut to space the attachment bolt off my bracket
Mounted bracket where the top clamp pinches the fork tube. Made sure it fit between and didnt stop the clamp from tightening but tight enough to hold it.
Installed the bolt and like that its finished. Pretty easy to do and has to be better then not having one. Think I will replace the needle and seat on it too Hope this helps others looking to do the same.
BozZX10 is offline
post #2 of 14 Old 01-30-2010, 10:29 PM
nickalltogether's Avatar
Looks good, looks factory!
2012 Kawasaki ZX-6R-Black
Clear Alternatives Tail Light
2005 Honda F4i-Red
Commuter stuff
2003 Yamaha Zuma-Fairy Silver
TPT 70cc Kit, Leo Vince ZX Exhaust, Malossi Delta Clutch, Scott's Damper Sticker
nickalltogether is offline
post #3 of 14 Old 01-30-2010, 10:31 PM Thread Starter
BozZX10's Avatar
Thanks man.
BozZX10 is offline
post #4 of 14 Old 01-30-2010, 10:55 PM
5-F Dawg's Avatar
great fabrication! this is for a Gen 1 zx10r? right?
BOOM!!! SHAKE AND BAKE
Last edited by 5-F Dawg; 01-30-2010 at 10:56 PM. Reason: jeez i just cant spell today!
5-F Dawg is offline
post #5 of 14 Old 01-30-2010, 11:04 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
Looks good, but I would be concerned in a violent tankslapper that your bracket and/or the triple clamp might not hold up. The stock bracket ties in to two mounting holes and sperads the load out under the whole width of the upper clamp. Just a thought
9R to 10R is offline
post #6 of 14 Old 01-30-2010, 11:50 PM Thread Starter
BozZX10's Avatar
Yes that is correct.
I have thought about that and thinking about bracing it. The stock 06 bracket looks pretty flimsy but does spread it to two smaller bolts. When I come up with a better bracket I will update with pics. I definately want it to be an effective mod and work correctly. Thanks for the input.
BozZX10 is offline
post #7 of 14 Old 01-30-2010, 11:53 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
I was thinking about this as well, and there are a few brackets out there that you can buy that clamp around the fork leg itself, particularly for this type of retrofit. I also though about drilling and taping the 04-05 upper triple for the 06-09 bracket, but its kind of cast and hollow underneath, not sure if that would work.
post #8 of 14 Old 01-31-2010, 12:04 AM Thread Starter
BozZX10's Avatar
I have the bracket so I will take off the top clamp and see if it is possible. Im with you though, that may not be an option.
BozZX10 is offline
post #9 of 14 Old 01-31-2010, 01:11 AM
jdgun_13's Avatar
Send a message via Yahoo to jdgun_13
If someone need a bracket set i have a hyper-pro set with the base and and the triple attachemnt.
not going to use it, prefer the under triple version instead.
another option is just pick up a 06 top triple and use that, they are pretty inexpensive as well.
jdgun_13 is offline
post #10 of 14 Old 01-31-2010, 01:55 AM
La Flama Blanca
9R to 10R's Avatar
Images: 102
I want to say someone tried to fit the 06 upper on the 04-05 lower and it did not work, I want to say the ofsett is slightly off, like it would line up with the fork tubes no problem but the center hole was slightle off. Hearsay, but I remember something about that. Now a whole triple clamp swap that would work no problem.
Scotts damper install logmaster Performance and Tech 3 05-08-2008 01:40 PM
Scotts Damper install Issue olec4 Performance and Tech 3 04-05-2008 10:56 PM
Scotts Damper Install fastburnzx-10 Performance and Tech 4 05-30-2006 11:10 PM
Steering damper install? busaforhire Performance and Tech 5 07-22-2005 09:52 PM
Muzzy (Hyperpro) damper install question YSR50 Performance and Tech 3 07-04-2005 01:05 AM
