06 Block off plate ? - Kawasaki ZX-10R.net
post #1 of 7 Old 02-25-2008, 02:15 PM Thread Starter
konichd's Avatar
So instead of spending 40 minutes sifting through the old post I rather just ask my questions and hopefully get direct answers:
1. When you get rid of the sensor in between the block-offs what do you do with the exposed plug? Also, can you pull the reeds out or do you leave them in?
2. The tube out of the airbox is no longer used, what do you block it off with?
Thanks again guys! Should have my block offs this week so I can finish this up.
konichd is offline
post #2 of 7 Old 02-25-2008, 02:49 PM
Drain Fade's Avatar
I just did this...actually I'm talking to A&R because the block off plates didn't fit :(. So I did what I did on my ZX9, I just put a 3/8in fuel line between both plates. I taped up the plug...and I rode today, all seems well.
Drain Fade is offline
post #3 of 7 Old 02-25-2008, 02:52 PM Thread Starter
konichd's Avatar
^^^Does not having the plug trip your FI light?
konichd is offline
post #4 of 7 Old 02-25-2008, 02:56 PM
Drain Fade's Avatar
Nope...no FI light today ;)
Oh and I used an old plug from an Ivan's block off kit I had for the airbox hole. You can get a plug from a hardware store...or you can silicon it up, tape it....whatever works.
post #5 of 7 Old 02-25-2008, 02:58 PM Thread Starter
konichd's Avatar
Did you remove the reed inserts?
konichd is offline
post #6 of 7 Old 02-28-2008, 11:53 AM
blackisfaster's Avatar
Just did this, flipped the stock plates over and flipped the reeds and rotaed 90 degrees, someone in the forum posted this, works fine and it is free. I used instant weld to cover the hole from inside the airbox. Not worried it will come off, it is instant weld for christ sakes,.. Peace
blackisfaster is offline
post #7 of 7 Old 02-28-2008, 12:43 PM
edouble's Avatar
I intsalled Ivans block-offs. The plug that is disconnected from the air switching device is left exposed. I zip tied mine out of the way. I also used Ivans supplied plug to cover the hole in bottom section of airbox. And yes the reeds are completely removed from the bike.
edouble is offline
mirror block off plate icepack The ZX-10R 28 07-20-2007 03:37 PM
Block Off plate installation help... Ground Zero Performance and Tech 14 07-18-2007 09:37 PM
Block off plate install... nite-ryder Performance and Tech 8 07-15-2007 12:39 PM
Block Off Plate Question axo250 Performance and Tech 21 03-12-2006 09:38 PM
Block Off plate installation help... dapszx10r The ZX-10R 3 01-01-1970 06:27 AM
