05 zx10r - very sluggish below 6000 rpm - HELP!!! - Kawasaki ZX-10R.net
post #1 of 6 Old 05-04-2008, 10:04 PM Thread Starter
greencheezeeta's Avatar
Unhappy 05 zx10r - very sluggish below 6000 rpm - HELP!!!
Hello all. As some of you may know, I just installed an 05 zx10r engine in my Z1000. While waiting on the exhaust to show up, I rode it several times with an open header and no "air temp" sensor. It was mental!!! I was able to power-up a wheelie in sixth gear, for crying out loud! Now it has a Muzzy sidewinder and an air box sensor installed. The power really seems to have died in lower rpms. No, I don't have a pcIII. It also skips and surges if pinned open when below 6000 rpm - happens in any gear. Once it hits 6000..... its business as usual. It does have iridium plugs, are they fouled out now? I was told that it would run rich without that sensor, and possibly foul the plugs. What do you all think? Yes, I know I need a pcIII. However, it should still haul ass like it is. What has happened?
greencheezeeta is offline
post #2 of 6 Old 05-04-2008, 10:32 PM
OneSLOW10's Avatar
Send a message via AIM to OneSLOW10
I had this same issue a few weeks back. My 05 10' was sluggish untill like 5-6k or so and surged pretty bad. Did a plug change and it solved the problem. The thing has run like a champ since and I have had no issues.
Hopefully this will be your issue. I say that b/c it's a easy $42,00 fix
Goodluck!
2005 PMR. Full Ti Evo 2, BMC Race, V-Stacks, PC3, IG Module, DJ QS (not installed), 1/5th throw (not installed), -1 +2 with Gold RK Chain, Speedo Healer V4, Removed 2ndaries, Red GiPro, Pilot Powers, Dual H.I.D.s, Brocks brackets and strap, Rear 2" Muzzy Drop, Vortex Rearsets, Scotts Damper, 2 HyperPro Dampers, Puig DB, ASV Levers, Titax Levers, Pazzo Levers, Kill switch (made to look like it's mounted), CA front/rear lights and a owner who adores her...
OneSLOW10 is offline
post #3 of 6 Old 05-05-2008, 01:16 PM Thread Starter
What kind of plugs should I go with? Iridium or maybe cr9ek or... ?
post #4 of 6 Old 05-05-2008, 01:29 PM
zx10Duran's Avatar
I would say go with stock plugs till you get a pc3 that would be an expensive change if it kept fouling out
zx10Duran is offline
post #5 of 6 Old 05-05-2008, 01:45 PM
OneSLOW10's Avatar
OEM baby
post #6 of 6 Old 05-05-2008, 01:52 PM Thread Starter
Thanks a ton fellas. I'll buy them today.
Sluggish throttle Bombtek93 Performance and Tech 9 03-07-2008 06:48 PM
6000 Posts Ara The Out House 21 04-04-2007 10:54 AM
help bike wont rev over 6000 04 10r please streetfighter Performance and Tech 8 01-07-2007 04:06 PM
2006 ZX10R for sale $6000 *SOLD* sumjoeguy Parts, Gear and Accessories 49 03-31-2006 09:28 AM
Dealer told me NOT to get an '05 b/c its sluggish?? vettewreck The ZX-10R 63 10-21-2005 02:16 PM
