05 ZX10r shutoff died - Kawasaki ZX-10R.net
post #1 of 5 Old 04-25-2008, 08:23 AM Thread Starter
Hey guys
Upon returning from Costa Rica to ride my 10R, aquick ride results in a dead bike.
A little history. 05 5K miles stock,ridden every week,Aftermarket key that is kinda hard to turn,green...
Turning into a corner after a 20 min ride and the power just shuts off. Wiggled battery connections at battery and nothing. Wait about 20 min and bike will power on and crank and then die. After that Nothing,decide to get a new battery because this one might have a bad cell and is 3 years old.
Charge new battery 12 [email protected] 1.5 amps. Install in bike,get about 500 ft and go to turn and then it dies again. Nothing after that.
Possible problems
bad key switch
Wiring problem
battery wasn't fully charged/bad
voltage regulator or other
I'm thinking towards key switch or wiring problem because it died both times attempting to turn .
What do you guys think? I tried to search shutoff and died and came up with nothing.
Thanks
Mr.Fizzer is offline
post #2 of 5 Old 04-25-2008, 08:41 AM
MIA Ex-Mod
Tread70's Avatar
Is it only happening in a corner? Does it matter which corner, right or left? Two more possibles, kickstand switch...this has happened to a few members. And the tip over sensor, not a typical problem but a possible.
Try the kickstand switch first, unplug it and jump it between the connectors in the plug. make sure your kickstand is fully up, and go for a ride. Warning, the bike, if done properly, will crank and run with the kickstand down. If after the ride it doesn't shut off, this is the culprit, if it does shut off then look at the tip over sensor. I would also suggest getting a service manual either hard copy or download it here. Check to see if your are getting any error codes from the ecu.
Tread
2004 PBO zx10-r pazzo, seat cowl, yoshi Ti TRS bolt on, PC3, Speedo-Healer, Hyperpro, Braided lines, 16-40, Sato sets, ZG dark screen, and more.
Tread70 is offline
post #3 of 5 Old 04-26-2008, 03:18 AM
Images: 26
Tread
sounds like it safety switch
anthonyzx10r2008 is offline
post #4 of 5 Old 04-28-2008, 10:37 AM
sextaafondo's Avatar
Does the lights and the cluster also die?
or just the engine?
Checked the Main Fuse out?
sextaafondo is offline
post #5 of 5 Old 04-28-2008, 10:40 AM
Shorty's Performance
madnessracing's Avatar
that sound like a bad ground!!
madnessracing is offline
bike died, need help ninjakris Performance and Tech 11 09-30-2007 05:19 AM
My 10'er died! Can anyone help??? Dennis Nielsen Performance and Tech 18 08-01-2007 04:00 PM
my uncle-in-law died hesaves0211 The Out House 24 06-18-2007 11:47 AM
This is how super mario died. sabersaw30 Pictures and Videos 8 01-21-2005 10:12 PM
2 riders died.(be careful) sabersaw30 The ZX-10R 3 07-16-2004 09:50 PM
