05 ZX10 crank no start - Kawasaki ZX-10R.net
post #1 of 9 Old 10-26-2008, 09:50 AM Thread Starter
hello all
just bought a wrecked zx10 and i`m having a hard time getting it running. i`m in need of a wiring diagram for it. the bike had some damage to the main harness and the ecu had been stolen. i picked up a used harness and ecu on ebay. i had the bike run for about 15 seconds and have not since been able to get it running again. i`d like to bypass the tip over sensor because i suspect it. i have spark but no injector pulse or fuel pressure. if anybody could offer advise (especially on how to bypass the tip over sensor) or a wiring diagram it would be much appreciated. thanks, cory
corybusa is offline
post #2 of 9 Old 10-26-2008, 10:00 AM
can we ride yet!?!?!?
coolgjc's Avatar
https://zx-10r.net/forum/showthread.p...service+manual
check out this thread. you should find what your after
coolgjc is offline
post #3 of 9 Old 10-26-2008, 10:01 AM Thread Starter
i forgot to ask does any one know if the tip over shuts down the pump and injectors? if not maybe i am barking up the wrong tree? thanks, cory
corybusa is offline
post #4 of 9 Old 10-27-2008, 11:53 AM
Tip over sensor definitely shut down the pump. But, if you turn off the kill switch then back on, it should reset the tos.
Since it was wrecked, you need to find the tos and make certain that it is in the proper orientation. Once it's right side up, turn the key on, cycle the kill switch and it should start the fuel pump immediately. Start the engine and enjoy!
papa rocket is offline
post #5 of 9 Old 10-28-2008, 03:28 PM Thread Starter
thanks guys. according to the manual that cooljc pointed out the tip over sensor shuts down fuel and spark so it isn`t the tip over sensor. i think i`m on the right track now just need to find the time to get out to the garage and get at it. i`ll post the results. cory
corybusa is offline
post #6 of 9 Old 10-28-2008, 09:29 PM
sextaafondo's Avatar
Is the FI led blinking?
sextaafondo is offline
post #7 of 9 Old 10-28-2008, 09:33 PM Thread Starter
no i don`t have a cluster. it was likely stolen by the same jerk who took the battery and ecu. thanks, cory
corybusa is offline
post #8 of 9 Old 10-29-2008, 06:49 AM
Geting a cluster can save you BIG time.
BTW, check the kick stand switch out.
post #9 of 9 Old 10-29-2008, 03:20 PM Thread Starter
if i was planning on keeping this bike i would gladly buy a cluster but i just want to get it running so i know the engine is ok before i part the bike out. thanks, cory
corybusa is offline
Who pays the most insurance on their ZX10 and i'll start..... edgey999 The Out House 125 10-07-2015 12:32 PM
'06 - Crank No Start ? lyketobyke Performance and Tech 6 11-25-2008 09:16 PM
06' zx10 no start robdog Performance and Tech 1 10-10-2008 08:41 PM
05 zx10 no start canadian kawi Performance and Tech 16 01-12-2008 02:45 PM
03 636 Crank bearings.... KIRK_ADAMS ZX-6R & ZX-6RR Archives 3 07-06-2007 11:04 PM
