05 Winter Project - Valve Adjustment Required? - Kawasaki ZX-10R.net
post #1 of 5 Old 03-11-2011, 10:33 AM Thread Starter
Hey,
So I've recently started my winter project and thanks to the help I got in this forum from other members its been a breeze so far. The following is a list of what I've purchased for my 10.
1. Competition Werkes Fender Eliminator
2. Puig Racing Double Bubble Windscreen
3. K&N Performance Air Filter
4. Two Brothers Racing M2 M5 VALE Slip On
5. Carbone Lorraine SBK-5 Front Pads
6. Carbone Lorraine RX3 Street Rear Pads
7. RK Chain / Vortex Sprockets 520 Chain Conversion Kit
8. EBC SRK Clutch Rebuild Kit
9. APE Manual Cam Chain Tensioner
10. Western Powersports Battery
11. Odds and Ends (Tank pad, stickers etc)
I've already installed the fender eliminator kit, brake pads, air filter, double bubble, exhaust, chain and sprokets, manual cam chain tensioner and battery.
I have two tasks left on my list to do and these are the clutch install and valve check. From installing clutches on my old 750Z and from what I've read here on this forum I'm confident this task should be easy and I'm not overly concerned about it, however I am concerned about tackling the valve job on my own since I've never done a job like this.
My 05 has just over 23 000kms on it and a friend of mine said I should be getting the valves checked soon. Are there symptoms of valves needing adjustment and is this something that needs to checked ASAP? This is something I will have to try myself since the nearest shop that can check these for me is about 4 hours away. If I don't check/adjust the valves what risk am I taking?
Thanks again for everything folks, thus far you guys made things much easier for me.
Cheers
muggz is offline
post #2 of 5 Old 03-11-2011, 10:45 AM
Quick10's Avatar
Originally Posted by muggz View Post
Hey,
My 05 has just over 23 000kms on it and a friend of mine said I should be getting the valves checked soon. Are there syptoms of valves needing adjustment and is this something that needs to checked ASAP? This is something I will have to try myself since the nearest shop that can check these for me is about 4 hours away. If I don't check/adjust the valves what risk am I taking?
Cheers
Yes it is important that you do the check. You also need to check the valve spring retainers as well. If you don't do this check and make the adjustements to keep everything in spec you take the chance of having to spend big money to have the head rebuilt and possibly the motor itself if you end up dropping a valve.
I had mine checked at 13K miles and had one shim on the exhaust side out of spec. At 20K miles I has 3 broken retainers and had to have the head rebuilt to the tune of $1700. Luckily I didn't drop a valve. Don't let your scheduled maintenance lapse.
Quick10 is offline
post #3 of 5 Old 03-11-2011, 11:11 AM Thread Starter
Do you know of any thread links on this forum that describe this procedure or even show some pictures that could assist me? Also when i pull the valve covers off, is the gasket reuseable or should I order one? I'm about to place an order for a valve shim kit and I'm also going to order the retainers to swap out just to be on the safe side.
muggz is offline
post #4 of 5 Old 03-11-2011, 11:19 AM
Quick10's Avatar
https://www.zx-10r.net/forum/showthread.php?t=71196
This link will take you to a thread that has a couple of other links with pictures and tutorial. I would go ahead and replace the gasket although it is probably ok to reuse.
Quick10 is offline
post #5 of 5 Old 03-11-2011, 11:40 AM Thread Starter
Awesome thanks for the help, safe riding!
Cheers
muggz is offline
Valve adjustment rafa The ZX-10R 6 06-28-2010 03:56 AM
valve adjustment ??? spanky3780 Performance and Tech 5 11-11-2009 04:15 PM
Valve Adjustment walkthisway21 Performance and Tech 23 06-23-2008 02:53 AM
Valve adjustment done Tread70 Performance and Tech 24 10-18-2006 09:03 PM
