05 headlight problem.....STILL - Kawasaki ZX-10R.net
post #1 of 11 Old 07-31-2010, 10:45 AM Thread Starter
Tristkm's Avatar
Send a message via AIM to Tristkm
Hi again, about a month ago I posted my problem on here, which was that if the bike hit a bump of some sort, the headlight would shut of, along with the main beam not working leaving only the two side lights. The headlight would not come back on unless you slow to a near stop.
I've changed the fuse, changed both bulbs and still no change.
So the main dealer had it and could not find any breaks in the wireing system. So he put a new relay on today and still no differant. It's really ****ing me of now.
What the he'll could it be?? Where are the wires I should be looking for?
Surely you boys must know what your talking about, bEcause I don't have a clue :(. Please help me
Tristkm is offline
post #2 of 11 Old 07-31-2010, 11:31 AM
Teeks's Avatar
Just to clarify both high and low beam go out, or just the low beam thats always on? If thats the case, it could just be a bad bulb. I have seen once or twice in car applications (similar style bulb) that car can actually be a small break in the filiment, and the bulb will work sporaticlly. That may not be the issue, but if everything else checks out it may be worth a shot to replace it.
Originally Posted by -Op- View Post
Unless Scout says dont do it. Then, really, just do it.
Originally Posted by or10r View Post
I know its blistering fast but you cant outrun ugly.
Teeks is offline
post #3 of 11 Old 07-31-2010, 12:29 PM Thread Starter
Tristkm's Avatar
Yes both go out, they are both run o the same fuse, I'm so confused
Tristkm is offline
post #4 of 11 Old 07-31-2010, 12:37 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
Check the plugs-pins in the headlight harness.......
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
post #5 of 11 Old 07-31-2010, 12:48 PM Thread Starter
Tristkm's Avatar
What am I checking for
Tristkm is offline
post #6 of 11 Old 07-31-2010, 12:51 PM
TMY10ER's Avatar
Check the actual "plug" and make sure they are connected properly, maybe even get and spray some electrical contact cleaner and spray in both ends of the plug? i had the exact same problem on another bike i had and it was simply the pins in the male side of the headlight plug were loose and not making contact all the time!! that shit drove me nuts till i figured it out.
TMY10ER is offline
post #7 of 11 Old 07-31-2010, 01:14 PM
I'd be looking at where the cables go into the fuse box, I had a YZF750R with exactly the same problem and it was a lead that had corroded away to nearly nothing, just a green crust where it joined a connector.
doug_uk is offline
post #8 of 11 Old 07-31-2010, 01:24 PM
Still here
ZX10Miami's Avatar
I've had the actual hi/lo beam switch on the bar go bad on a couple of older bikes and cause intermittent problems like that.
I opened it up and had to resoldier the connections in the switch.
I'm not even sure if our bikes do this since only the marker lights come on when you turn the key-but many starter switches will cut the headlights while you are using the starter to ease the load on the batt.
I once had that switch go bad on an older bike and leave me with no lights and no blown fuse.
Sarah Palin and friends can call it a snow machine all they want but Yamaha, Polaris and Bombardier plus the related magazines all seem to call them Snowmobiles.
Snow machines create snow on ski slopes. Just sayin'
ZX10Miami is offline
post #9 of 11 Old 08-01-2010, 07:42 AM Thread Starter
Tristkm's Avatar
I've checked all them connections and cleaned them, they all look good, still no differant though, looks like the MD will have to sort it
Tristkm is offline
post #10 of 11 Old 08-31-2010, 02:57 PM Thread Starter
Tristkm's Avatar
Hey youl like this, I've got the bike booked in, about a months time. Any way today started the bike up and the headlight wouldn't come on at all, only main beam worked. WHAT?!?!? Anyway i kept the main
beam on and took it on a mega bumpy road that it always goes out on and......it didn't! It stayed on. What do you make of that then!
Tristkm is offline
Headlight problem.... HIDs are a NO-GO!!!!!!!!! workin2hard The ZX-10R 13 08-01-2010 11:35 PM
05 zx10r headlight problem Tristkm The ZX-10R 4 07-03-2010 04:42 AM
Headlight problem c11x Performance and Tech 5 05-27-2010 11:11 PM
04 Headlight !!! Enzo10 Wanted: Buy or Trade 5 04-13-2007 10:06 AM
