05 brakes - Kawasaki ZX-10R.net
post #1 of 5 Old 11-23-2008, 03:12 PM Thread Starter
gbillzx10r's Avatar
05 brakes
i installed new ebc hh front brakes today and now they are noisy (grinding) as hell and feel like they are sticking, any answers please
gbillzx10r is offline
post #2 of 5 Old 11-23-2008, 06:19 PM
ivyjohn865's Avatar
Yeah if you replace your pads only, then they will have to break into the groves of your rotors. Whilst they are breaking in they will make grinding/squeaking noise. My bike did that when i put my galfers on. One thing you should do tho is take some brake cleaner on a rag and wipe your rotors down this will take all of the embedded brake dust off and they should quiet down a little bit. give em about 200 miles to shut up completely.
ivyjohn865 is offline
post #3 of 5 Old 11-23-2008, 07:15 PM Thread Starter
gbillzx10r's Avatar
cool thanks
post #4 of 5 Old 11-23-2008, 07:49 PM
ivyjohn865's Avatar
no problem man
post #5 of 5 Old 11-26-2008, 11:55 PM
shoginator's Avatar
Clean the hell out of your calipers. Pull everything off, pump the pistons in a bit (not all the way) and use Bleche-wite and a tooth brush to get eveything clean. Then dry and push all the pistons back in and reassemble. This will give a clean surface for the pistons to glide in with the new pads. And yes, clean the rotors with brake-clean after deglazing them with scotch bright. Don't even think about using the old brake fluid. You need the lubicity of fresh fluid.
On another note - the stock 4 pad HH Tokico pads are just fine - even for extreme racing. The master should be changed out for a unit from a 06-07 (radial unit). Proper and complete bleeding is KEY! The second most important thing is PROPER BLEEDING. The third most important thing is no air in the system! Is this making a point yet? Two of my customers went through all the BS of changing out there 4 pad unit for what they thought was the plan with Honda and other 2 pad units. WRONG! When they rode my bike on the track and found out I was using stock pads and calipers - they almost had gave birth right there and then.
shoginator is offline
brakes...........? fallfornoone ZX-6R & ZX-6RR Archives 4 06-23-2008 03:44 PM
Brakes Blink180Wilhelm Performance and Tech 32 03-30-2008 09:42 PM
Do the brakes get better? johnny napalm Performance and Tech 44 11-09-2006 02:20 AM
Brakes. Speedyj Performance and Tech 1 09-24-2006 05:10 AM
Brakes RickRoush03 The ZX-10R 6 09-17-2005 10:50 PM
