05 bike no start no fuel help! - Kawasaki ZX-10R.net
post #1 of 4 Old 11-13-2008, 12:00 PM Thread Starter
ok guys,
I need some help
05 10r will not start just cranks, I left bike out in heavy rain for 3 days, when I moved it, it started right up and went about 30 feet before it died, tried to restart and just sputtered then nothing...
so far I have figured out that the fuel pump is coming on and pumping gas like normal when the key is cycled on.
and the ignition system is still working (when gas is poured into throttle bodies bike starts up fine)
I was thinking tip-over switch but somewhere on here i saw that kills the ignition as well as fuel??
and I would think that the kickstand switch would do the same right??
for some reason the injectors are not spraying. ECU?, fuel pressure?
any ideas? thanks guys!!
motorkid04 is offline
post #2 of 4 Old 11-13-2008, 12:01 PM
MIA Ex-Mod
Tread70's Avatar
possibly water in the gas????
2004 PBO zx10-r pazzo, seat cowl, yoshi Ti TRS bolt on, PC3, Speedo-Healer, Hyperpro, Braided lines, 16-40, Sato sets, ZG dark screen, and more.
Tread70 is offline
post #3 of 4 Old 11-13-2008, 03:34 PM
sextaafondo's Avatar
Water in the tank.
sextaafondo is offline
post #4 of 4 Old 11-13-2008, 07:04 PM
10roller's Avatar
check all your fuses?
10roller is offline
Tags
fuel, no start, tip over
HELP!!!! Bike won't start! afskypilot Performance and Tech 26 02-28-2010 04:51 PM
bike won't start russell Performance and Tech 12 03-15-2008 10:50 PM
Bike won't start ?? WRECKSHOP General Motorcycle Discussions 1 01-13-2008 12:38 PM
Need Help bike won't start CMG Performance and Tech 2 09-26-2007 10:09 PM
Need Help Bike Won't Start? D on 10R Performance and Tech 16 09-17-2007 03:59 PM
