Gen 1: 2004-2005 04 zx10r having trouble getting it started - Kawasaki ZX-10R.net
post #1 of 3 Old 04-11-2011, 11:49 PM Thread Starter
bringthemosh's Avatar
it cranks then sputters and backfires, any ideas, the servo for the exhaust under the seat moves when i turn the key on but the cables seem to be jammed would that cause the bike not to start? dont have any fi light on but do have trouble with mice checked the air filter and throttle bodys no signs of anything wrong there. wondering what the exhaust cables should do and if its a sign there clogged and if I should start there
thanks for any help
bringthemosh is offline
post #2 of 3 Old 04-16-2011, 04:52 PM
Bleed_green_GKB's Avatar
I would. Have you tried opening the throttle while cranking it? My servo used to get stuck and I had to crack it just a bit to get it to fire.
Bleed_green_GKB is offline
post #3 of 3 Old 04-17-2011, 02:37 AM
Late Apex
Solo-Six's Avatar
thanks for any help
Disconnect the cables while the bike is off. It is open when bike powers off.. If the bike fires normal you need to troubleshoot the cable binding and possibly replace the cables or take them off all together ..
If bike does the same thing you have a different problem . Just come back and report your findings . We will help ya figure it out if that s not your issue
Solo-Six is offline
Tags
10r, starting
Having Trouble Keeping My ZX10R Started Labowski General Motorcycle Discussions 15 12-02-2010 06:01 PM
rebuilding my zx10r 08 back end wire trouble faulkner Performance and Tech 10 10-02-2009 03:51 PM
well i done started something at the gap rayszx10r The Out House 13 07-31-2009 10:44 AM
04 zx10r headlight trouble help blown450r The ZX-10R 7 06-26-2009 07:01 PM
04 zx10r trouble? sturgill_13 The ZX-10R 9 06-04-2008 04:41 PM
