04 zx10r Coolant Leak Help - Kawasaki ZX-10R.net
post #1 of 3 Old 03-05-2011, 05:27 PM Thread Starter
Hero's Avatar
I noticed the coolant starting to leak from my bike last week. Strangely, it appears to be coming from behind the coolant pump instead of from any of the hoses. Before I start taking things apart, does anybody know what this could be from? The reason why I ask is because it seems kind of strange to be coming from that area instead of from a loose or broken hose.
Hero is offline
post #2 of 3 Old 03-06-2011, 11:19 AM
Sorry, but it sounds like you need a new pump. Just had to do this on my '04. Same symptom you describe.
CanyonCarver is offline
post #3 of 3 Old 03-06-2011, 11:26 AM
my10r's Avatar
Images: 7
check the rad hasnt split at the back ! happened to me and turned the rad had split in 3 places ! apparently due to rust inside because i hadnt change the coolant regularily enough.
my10r is offline
coolant leak edouble Performance and Tech 3 05-03-2010 04:50 AM
Coolant leak Help??? kneedragger Performance and Tech 37 10-20-2008 03:46 AM
Coolant Leak 1kdoubler The ZX-10R 16 11-08-2005 07:03 PM
Coolant leak bluebyyouz Performance and Tech 12 12-28-2004 07:20 PM
Coolant leak??? BlackNinja The ZX-10R 19 05-16-2004 09:44 PM
