04 main throttle sensor - Kawasaki ZX-10R.net
post #1 of 3 Old 03-01-2008, 11:24 AM Thread Starter
Hi guys
Is there anybody who had a malfunction with the "main throttle sensor"?
If so what was the symptoms?
Thanks
K.makry is offline
post #2 of 3 Old 03-02-2008, 10:18 PM
bugman53's Avatar
If the sensor went bad your fuel injection would not know what throttle opening you are at and the fuel mixtures would be all over the place. It would probaly back fire and not rev well or foul the plugs.
bugman53 is offline
post #3 of 3 Old 03-03-2008, 08:00 AM Thread Starter
When on full throttle from relatively low revs the bike was hitting the 8500rpm mark and then it was like it was out from fuel.
The bike simply refuses to accelerate from the 8500rpm mark.
My mechanic checked the main throttle sensor and the voltage should be 4.92v but it was 3.69v.
So we decided that the problem comes from this sensor.
K.makry is offline
Throttle position, Gear, Speed and RPM sensor CMG Performance and Tech 9 03-12-2007 01:12 PM
TRE and PCIIIUSB and Sub Throttle Sensor. zapik Performance and Tech 9 12-04-2006 04:35 PM
Ivan TRE Throttle sensor question... sneaky Performance and Tech 35 10-18-2006 02:37 PM
Sub Throttle Sensor coach Performance and Tech 42 10-16-2006 03:57 PM
