'04-'05 Brake Thread #2 million and 1 - Kawasaki ZX-10R.net
post #1 of 6 Old 04-04-2006, 08:34 PM Thread Starter
MAD750's Avatar
Question '04-'05 Brake Thread #2 million and 1
After searching here, speaking to some local owners and from my experience the front brake is shite. Cheap lines seem to be part of the problem with the master cylinder being the main culprit.
Ive bled the brakes using many methods. Im confident the brakes are as good as theyre going to get. The inconsistency of the lever is scary as hell.
The Brembo seems like a lot of hassle to get the brake light switch and everything hooked up. Has anyone put a 06 MC on an 04-05 yet?
Has anyone tried a GSXR MC? The calipers on my 05 750 are Tokico and look very similar but use a different pad setup. Besides being killer brakes the 750 MC is a Tokico and it looks like the brake light switch on the 10 will plug right in.
MAD750 is offline
post #2 of 6 Old 04-04-2006, 08:38 PM
Hillbillie Mod
hillcountry10r's Avatar
Images: 31
I’ve bled the brakes using many methods. I’m confident the brakes are as good as they’re going to get. The inconsistency of the lever is scary as hell.
The Brembo seems like a lot of hassle to get the brake light switch and everything hooked up. Has anyone put a ’06 MC on an ’04-05 yet?
Has anyone tried a GSXR MC? The calipers on my ’05 750 are Tokico and look very similar but use a different pad setup. Besides being killer brakes the 750 MC is a Tokico and it looks like the brake light switch on the 10 will plug right in.
I've used the m/c off the 06 gsxr 1K...
dont knos if that helps you or not...but it is radial and I imagine you can get it for relatively cheap....and Im unsure of the brakeswitch...
as far as the 750 goes...I have on in my garage...and it looks like it would work...you just need to be wary of what kind of threads your banjo bolt is or will need to be.
and it is possible to get the 10 brakes pretty good...not as good as with the g1K radial m/c...but good none the less!
James 3:7,8
hillcountry10r is offline
post #3 of 6 Old 04-04-2006, 08:51 PM
Chickenstrip Eater
SUPER K's Avatar
Send a message via MSN to SUPER K
hook up with Brad @ superbike supply.the switch he sent with my brembo worked just fine, snug fit,but not as bad as it sounds.250$ complete 19x18 with res. and switch delivered.the feel is so sweeet!!well worth the $ and time
SUPER K is offline
post #4 of 6 Old 04-04-2006, 08:56 PM
Still here
ZX10Miami's Avatar
check your other post- tune me up, I put info and links there.
Sarah Palin and friends can call it a snow machine all they want but Yamaha, Polaris and Bombardier plus the related magazines all seem to call them Snowmobiles.
Snow machines create snow on ski slopes. Just sayin'
ZX10Miami is offline
post #5 of 6 Old 04-04-2006, 09:00 PM Thread Starter
MAD750's Avatar
This sounds promising. I'm not sure of my terminology here but there is a "ratio?" of the the MC piston to the caliper piston. I believe Brembo offers three choices? Was the 06 GSXR 1K MC overly sensitve? Or did it require a lot of pressure?
MAD750 is offline
post #6 of 6 Old 04-05-2006, 05:28 AM
Big Daddy's Avatar
Images: 38
Theres also the 05 zx6 (636) radial MC to consider, in fact it may very well be the same as the 06 10r.
Big Daddy is offline
$250 million????? Tread70 The Out House 19 02-11-2006 03:28 PM
help with thread subscriptions?? storm ZX-10r.net Site Help, Suggestions and Questions 6 11-18-2005 11:26 AM
