04/05 Atmospheric Pressure switch loaction? pic? - Kawasaki ZX-10R.net
post #1 of 9 Old 02-07-2010, 10:06 AM Thread Starter
Dare-x's Avatar
Can somebody help me with this, but I can looking for
Atmospheric Pressure switch loaction? and or pic of what it looks like?
bike: 2005 ZX10r
Dare-x is offline
post #2 of 9 Old 02-07-2010, 10:25 AM
Speed Freak
garth285's Avatar
located under the mid section of the tail section, in front of the passenger seat and behind the driver seat.
garth285 is offline
post #3 of 9 Old 02-18-2010, 04:53 PM
might sound dumb but what does this do exactly?
air30force is offline
post #4 of 9 Old 02-18-2010, 04:56 PM
Speed Freak
garth285's Avatar
tells the bike the current outside atmospheric conditions so the bike can adjust to it.
garth285 is offline
post #5 of 9 Old 02-18-2010, 05:07 PM
is it like a reset switch or like an on or off sorry im still new to bikes trying to learn as much as possible
post #6 of 9 Old 02-18-2010, 07:53 PM
Supercharged Mod
It is not a "switch", it is a "sensor". It doesn't give an "on/off" type signal. It gives a voltage that is in proportion to atmospheric pressure.
The ECU uses this information (and also from many other sensors) to calculate how much fuel to inject. This is how the fuel-injected engines compensate for altitude. At high altitude, the atmospheric pressure is lower, so it reduces fuel delivery in proportion so that the engine still runs correctly. A loss in power at high altitude is unavoidable, but maintaining the air/fuel ratio correct ensures that driveability is maintained and that the loss in power is minimized.
GoFaster is offline
post #7 of 9 Old 02-18-2010, 08:15 PM
OOphLAMEr's Avatar
Send a message via AIM to OOphLAMEr
This post got me thinkin...
Does anyone know the refresh rate on the sensor...how often it sends a signal to the ECU?
If one were to relocate the atmospheric sensor to the inside of the ram air tube, as far forward as possible, would this improve the a/f ratio at high speed on the highway? Or, is the refresh rate too slow to provide any benefit?
All Glory to the Hypnotoad!
OOphLAMEr is offline
post #8 of 9 Old 02-18-2010, 08:21 PM
Speed Freak
garth285's Avatar
no this sensor is located there for a reason, there is another sensor on the throttle bodies that senses other but this sensor is to get a condition where wind is not blowing acros the opening to give it any in-accurate readings.
garth285 is offline
post #9 of 9 Old 02-18-2010, 09:00 PM
Supercharged Mod
There's no way to know how often the ECU takes a sample from this sensor. Atmospheric pressure is generally a slow-changing function; it is not necessary to sample it at a high frequency. But, it's also not very difficult for a modern ECU to take a sample at a high frequency.
Modern fuel injection ECU's recalculate the injection quantity on every revolution of the engine. There's no reason it couldn't sample the barometric pressure sensor at that very same frequency - although barometric pressure doesn't change with each revolution of the engine, so there is no need for it to do that. No way to know. Also, doesn't matter too much.
GoFaster is offline
Pressure switch banjo bolt RDLYN13000 Vendors deals 1 12-14-2009 03:18 PM
Rear brake pressure switch Green Parts, Gear and Accessories 6 02-26-2009 12:50 PM
07 atmospheric pressure sensor konichd Wanted: Buy or Trade 0 07-22-2008 09:13 PM
pressure switch cnote The ZX-10R 2 04-25-2008 10:09 PM
Rear Brake Pressure Switch themightymezzo Vendors deals 6 12-22-2007 12:05 PM
