**Caution** Fuel Pumps - Kawasaki ZX-10R.net
post #1 of 25 Old 12-10-2008, 12:06 AM Thread Starter
axo250's Avatar
Send a message via AIM to axo250
Exclamation **Caution** Fuel Pumps
For those with Aftermarket Fuel Pumps or Pumps that have been removed....
I have a Walbro fuel pump in my bike. While riding this past weekend the bike shut down all of a sudden. It never cranked back up. I got back home and took things apart and found the problem.
There is a white plastic clip that connects the metal pump to the black housing. As the fuel pushes through the black housing it is sent through the tank interface and out the fuel line. I noticed that the black housing was seperated from the pump by a rubber boot. Well the pump and boot was seperated from the black housing. After taking everything apart the white plastic clip loops were broken therefore not keeping the assembly together. This could be due to stress induced from taking the assembly apart and this could also be due to the higher fuel pressure that the aftermarket fuel pump produces. I'm going to try to get a metal clip fabricated to eliminate this problem for good because you can only buy the entire pump/interface assembly from Kawasaki.
I know this might be somewhat confusing to those who haven't had this apart. I took pictures and can post them if anyone is interested in this problem. I just wanted to give a heads-up to everyone out there.
-Derrick
"Besides, my ZX-10R eats GSX-Rs for breakfast." -- SportRider Magazine Article
axo250 is offline
post #2 of 25 Old 12-10-2008, 12:42 AM
thrill's Avatar
cool ... my pump has been whinging at me for ages, and is just getting worse
Bill - GI Pro, Hindle slip on, Smoked screen, ZX14 brakes.... Well, you feel lucky, punk? You shouldn't, this is a 10R
thrill is offline
post #3 of 25 Old 12-10-2008, 02:23 AM
FEELING LUCKY, PUNK ?
Lucky10R's Avatar
Images: 19
-Derrick
you can search my posts, same thing happen to me.
Lucky10R is offline
post #4 of 25 Old 12-10-2008, 09:16 AM
Speed Freak
garth285's Avatar
glad ya found it, get her fixed so we can duke out the 2mm vs 3mm lol
garth285 is offline
post #5 of 25 Old 12-10-2008, 10:01 AM
Red_ninja's Avatar
Dont have one in my bike, but the same thing happened in my car a while ago. I believe that there was a separate kit that helps with this, or at least the shop charged me for a kit, which fixed it, knock on wood.
Red_ninja is offline
post #6 of 25 Old 12-10-2008, 11:49 AM
javeci01's Avatar
Send a message via AIM to javeci01
Happened to me twice. Luckily I was close to home. If you make that clip I'll buy one off you!
04 Pearl Blazing Orange ZX-10R
javeci01 is offline
post #7 of 25 Old 12-10-2008, 12:53 PM
sweetride10r's Avatar
post up those pics
bike is down for not but not out
turbo project is a slow go no money
Need some work done
call 586-214-2414
sweetride10r is offline
post #8 of 25 Old 12-10-2008, 04:02 PM Thread Starter
axo250's Avatar
The first pic gives you a good overall.
The second shows the way the pump and black housing should be.
The third is how I found it.
The fourth shows the plastic piece up close and how I feel about it.
I went to one machine shop and they told me 75-100 bucks to make one. I'm going to try one of the guys at work to see if he'll make one out of scrap left over from shuttle stuff.
Name:	Overall Assembly And Broken Clip.jpg
ID:	83736   Click image for larger version
Name:	Way It Should Be.jpg
ID:	83737   Click image for larger version
Name:	Good Closeup.jpg
ID:	83738   Click image for larger version
Name:	How I Feel About It.jpg
axo250 is offline
post #9 of 25 Old 12-10-2008, 05:20 PM
Speed Freak
garth285's Avatar
what about some heafty zip ties.....
garth285 is offline
post #10 of 25 Old 12-21-2008, 11:17 PM
slav's Avatar
Send a message via AIM to slav
how long have you had the pump? I've had my Walbro for over a year and no problems. The only problem I had was the first day because of some stupid o-ring came off from the stock pump, so when I was putting in the Walbro it didn't allow it to go completely in to the black housing and didn't let the fuel flow through so kept belowing the fuse.
Did you shave down the rubber piece on the buttom and the white v shaped spacer?
Does everyone here with this problem have a walbro?
slav is offline
gen1/gen2/gen3 fuel pumps interchangeable ? Lucky10R Performance and Tech 17 10-27-2008 08:16 PM
High Flow Fuel Pumps axo250 Performance and Tech 12 01-11-2007 08:23 PM
caution sign miykl Pictures and Videos 11 03-11-2006 04:06 PM
Wheelie caution!! Austin10RPowers The ZX-10R 2 09-12-2004 09:00 PM
