Where do you mount XT ultralap display? - Kawasaki ZX-10R.net
post #1 of 11 Old 01-27-2008, 08:02 AM Thread Starter
Anyone have a picture or description of how/where they have mounted the display unit of the XT Ultralap timer on an 06-07 10r? There's not much room there. Maybe some kind of clamp-on mount on the upper fork?
clausiam is offline
post #2 of 11 Old 01-27-2008, 08:19 AM
hangman39's Avatar
I velcro my reciever on the tip of the tail section and put the display in the trunk will see if I have pic that shows it
hangman39 is offline
post #3 of 11 Old 01-27-2008, 08:27 AM
hangman39's Avatar
I put the display in the trunk and then check it after each session do not want it out where it will distract me while running.
post #4 of 11 Old 01-27-2008, 08:29 AM
green_zx's Avatar
Send a message via AIM to green_zx
Here is how I mounted mine.
I got the mount from this place
http://www.laptimerholders.com/
I got the 50mm. It is a little bigger so I used a piece of plastic tube to make it fit snug. I have used it that way all season and had no problems. Also by buying the 50mm mount it is easy to transfer as most forks are 50mm now.
green_zx is offline
post #5 of 11 Old 01-27-2008, 09:21 AM Thread Starter
Perfect, thanks.
clausiam is offline
post #6 of 11 Old 01-27-2008, 12:20 PM
I've mounted the display on the top triple with a stem stand that I made. The receiver is mounted in the nose looking out through a 3/4" hole I cut in the fairing.
I think its important to be able to see your lap times after each lap, you can gauge if you've made improvements with line changes or anything else you've done differently. You can't remember when your looking at it back in the pits.
bender is offline
post #7 of 11 Old 01-27-2008, 12:54 PM
Felix el gato's Avatar
Images: 139
Velcro is your friend ....
I velcro'd the display on tank, couple inches from gas cap.
For the receiver I have 1 small velcro piece on uppers, on each side,
(depending on how many different tracks/configurations you go to) I can
swap/stick the receiver on either sides.
I NEVER look at my times during (track day)session..your eyes should
always be on the track.
Once the bike is on stands and warmers on, then I'll take a look.
(using the memory on the Mychron).
'06 green ZX-10R Race / '05 orangina ZX-10R track
Wera West Expert #95
______________________________________________
Felix el gato is offline
post #8 of 11 Old 01-27-2008, 01:02 PM
hangman39's Avatar
That is how I feel
post #9 of 11 Old 01-27-2008, 05:11 PM
I guess you fookers aren't very competive then
bender is offline
post #10 of 11 Old 01-28-2008, 11:47 AM
socal's Avatar
I'm with JP on this one: velcro to tank and wait till the session is over before checking times.
WSMC #644
socal is offline
Dynojet LCD Display ZX10Rip Performance and Tech 11 12-13-2007 06:17 PM
Dynojet Hub & Lcd Display Gb. 2whldealer Vendors deals 12 09-21-2006 12:08 PM
Rear Tag Display Wolfe The ZX-10R 26 04-21-2006 08:44 PM
06 display mrsuprafreak The ZX-10R 24 02-16-2006 06:34 AM
Orange Display? BeepeR The ZX-10R 3 07-21-2004 03:29 PM
