When to change the oil when dragging? - Kawasaki ZX-10R.net
post #1 of 10 Old 04-16-2006, 07:40 PM Thread Starter
bragg10r's Avatar
Question When to change the oil when dragging?
Hello all,
I was just wondering how long between oil changes most of you that drag race? I was thinking something between the lines of 300-500 miles? I might ride my bike to work every now and then, but I use it mostly for drag racing so i'm coming up on 500 miles before my last one. I was also wondering what oil I should use? My bike has 1400 miles on it. I started draging it when it had about 700 miles on it....I have put on about 500 miles going to the track and running the bike, and getting back home. Thanks for any insight.
Bragg
"Best" (Time Slip Proof) Run so far :
60ft:1.7
330ft: 4.5
1/8: 6.7 @ 113mph
1/4: 10.2 @ 142mph
bragg10r is offline
post #2 of 10 Old 04-17-2006, 01:35 PM
imadimetooo's Avatar
Thumbs up oil
Well it just depends on how many passes you got and if the bike got to cool down between rounds I would say it you made 12 pass in a test and tune and there was 15 to 20 min i would go ahead and change. Think about the clutch fibers that you used and the how hot the oil got good luck
FULL TI-FORCE CUSTOM MAP BY ADAMS 165.5 AND A BIG BIG SHOT OF (MO-FIRE) AIR BOX
imadimetooo is offline
post #3 of 10 Old 04-17-2006, 06:51 PM
rated zx's Avatar
mobil 1 5w 30- allows clutches to slip without burning up, also frees up about 2 horses.
HACKSTALL RACING AND ENGINEERING (H.R.E)
rated zx is offline
post #4 of 10 Old 04-17-2006, 07:26 PM Thread Starter
bragg10r's Avatar
Thanks! Gonna change it this weekend!!
60ft:1.7
330ft: 4.5
1/8: 6.7 @ 113mph
1/4: 10.2 @ 142mph
bragg10r is offline
post #5 of 10 Old 04-17-2006, 07:28 PM
mobil 1 synthetic or nonsynthetic?
05 Ti 10
-Polished lips
-Lowered 2in
-15t front
-Front clear euros
-Undertail
-Full muzzy ex. w/ 10' can (Thanks to 1killer1litre!)
-PC III usb
-Vortex rearsets
-Pazzo shortys
-Def. more to come fuggars
low10 is offline
post #6 of 10 Old 04-17-2006, 07:29 PM
BANNED
mobil 1 is synthetic ..........mobil is the non synthetic
must be car oil thought ......id never use that in a 13,000 rpm engine ......... i use silkolene
oneradten is offline
post #7 of 10 Old 04-18-2006, 06:41 PM Thread Starter
bragg10r's Avatar
Yes it was running about 210-215 between runs....I also did double sometimes triple runs (meaning, i rode right back up to the start line after a run) I then take the oil cap off to allow to cool..... I will get it changed this weekend because I am getting the tires changed so might as well do the oil at the same time....thanks again...
60ft:1.7
330ft: 4.5
1/8: 6.7 @ 113mph
1/4: 10.2 @ 142mph
bragg10r is offline
post #8 of 10 Old 04-18-2006, 06:47 PM
Ruthless Racing's Avatar
Images: 9
I do this at the track especially if I'm running more than one class. If you will take a heavy duty rubber band, Tie wrap, etc. and pull the clutch lever in and use one of those things to hold the lever and take the oil cap off, the clutches are able to cool alot quicker.
Kenny Poppell
AMA Dragbike SuperSport #1000
2007 AMA Dragbike 1000SS National Champion
2007 1000SS 1/8th ET Record Holder 5.967
Best 1/[email protected] Best 1/[email protected] Stock Wheelbase
Special Thanks:
Performance Psycle
Richies Tires
http://www.XXXRacingFuel.com
http://www.SuperbikeSpecialties.com
http://www.Tsukigi.com
http://www.CycleConceptsRacing.com
http://www.myspace.com/ruthlessracing1
Ruthless Racing is offline
post #9 of 10 Old 04-18-2006, 07:12 PM Thread Starter
bragg10r's Avatar
Good info RR, thanks..
60ft:1.7
330ft: 4.5
1/8: 6.7 @ 113mph
1/4: 10.2 @ 142mph
bragg10r is offline
post #10 of 10 Old 04-19-2006, 08:37 AM
rated zx's Avatar
Good advice, if you keep a check on your clutch springs often,(like I do and RR probably does) keeping them compressed ecspecially while hot WILL shorten tension life of springs.
rated zx is offline
How to change your own oil & filter... El Diablo Performance and Tech 191 04-04-2016 03:10 PM
Impressions and questions after doing my first oil change myself... deputydog95 The ZX-10R 30 03-02-2005 01:23 PM
How to change your own oil & filter... El Diablo The ZX-10R 1 02-07-2005 11:28 PM
How to change your own oil & filter... El Diablo How To... 1 02-07-2005 11:28 PM
BREAK IN PROCEDURES FOR MAX HP TRUE OR FALSE? zixxer Archives 29 11-01-2003 12:43 AM
