Tire Warmer Reccomendations - Kawasaki ZX-10R.net
post #1 of 15 Old 08-23-2004, 03:29 PM Thread Starter
Ara
LE Post Whore
Ara's Avatar
Im looking to get a set of tire warmers and wanted to know if you guys had any reccomendations. I have looked up a few different ones so im basically just looking to get feedback from people who have the different brands. Im between the Chicken Hawk Pole Positions, the PD's and the Bandit Pro Line.
Thanks
Ara is offline
post #2 of 15 Old 08-23-2004, 06:21 PM
Send a message via AIM to gladding24
I know a lot of guys are fond of the Chicken hawks, built pretty well and last a long time. Easy on/off.
Stop Whining!!!
It ain't easy being Green ~ Kermit The Frog
Arguing on the internet is like running in the Special Olympics.....Even if you win...you are still retarded
CaliSuperbikes- "these are high strung machines, and we're giving them a constant dose of Red Bull"
gladding24 is offline
post #3 of 15 Old 08-24-2004, 09:38 AM
Chicken Hawks are a little expensive though.... Tyre Sox are a lot cheaper and do the same thing.
dnwhoop02 is offline
post #4 of 15 Old 09-01-2004, 10:00 PM
zeta xray's Avatar
I have never used any tire warmers but I will get to use a set of Chicken Hawks this Labor Day at a track day. I seem to remember that RoadRacing World Magazine did a track test of tire warmers a year or so ago and they thought the Chicken Hawks were the best. The racks of tires at the AMA Superbike races with Chicken Hawks must mean something. I used a temp gun on several set of tires that were heated by another, cheaper brand of tire warmer at a recent track day and I was pretty disappointed with the wide variety of temps that came from supposedly identical tire warmers. Not only was there a big difference in temps from one tire warmer to another but there was a big variation from one side of the same tire warmer to the other side.
zeta xray is offline
post #5 of 15 Old 09-02-2004, 01:42 AM Thread Starter
Ara
LE Post Whore
Ara's Avatar
I went with the Bandit Pro Team tire warmers. I will be using them for the first time at our track day on labor day. They are supposed to be really good and are the same ones that the Honda Moto GP teams use. Ill let you guys know how they work.
later...Ara-mri
Ara is offline
post #6 of 15 Old 09-02-2004, 12:57 PM
yeah, I realize that Chicken hawks perform better than some less expensive brands, but what I meant to say was that for someone who is buying tire warmers for the first time (and most likely doesn't even need them), one brand should work just about the same as another....
post #7 of 15 Old 09-04-2004, 07:40 AM
redelk's Avatar
We use Chicken Hawks, Tire Bandits and TyrSox. For ease of installation/removal, nothing beats the Hawks. The Bandits are not too hard to install/remove either, but the 2 part TyrSox are a hassle. All three seem to warm the tires well and none of them will cook a tire. The Bandits seem to be about 10 degrees warmer (170) than than the Hawks (160) and 20 degrees warmer than the TyrSox (150). Bandits also seem to warm up fastest, closely followed by the Hawks and the TyrSox are a distant third. As far as insulating the tire and holding the temps when unplugged, again, the Hawks and the Bandits are close with the TyrSox id a distant third.
Having said all that, one the "club level" (CMRA), about 60% to 70% of the teams use Hawks with the remaining using Bandits with a small sprinkling of TyrSoxs here and there. For the occasional track day riders, when properly used, all three would work just fine. Keep in mind that any tire warmer will heat up a tire, but none of them make a tire "race ready" before you even hit the track. More like 80%. So always do a lap or two before going WFO.
There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.
-Ernest Hemingway
redelk is offline
post #8 of 15 Old 09-06-2004, 11:59 PM
bikerscum's Avatar
Another tip: don't put a warmer on a tire, then set the tire on the ground. The weight of the wheel/tire (or if mounted, the weight of the bike) on one concentrated piece of the tire will cook a hole in the warmer. [smilie=b:
Does this bike make my butt look fast?
bikerscum is offline
post #9 of 15 Old 09-12-2004, 06:49 PM
Good point!
swft is offline
post #10 of 15 Old 09-16-2004, 02:51 PM
Go with the CTC brand! Its what we use on the Factory Graves bikes. They are very well priced at 385.00 and are super durable. Chuck
Chuck Graves is offline
Track day tire pressure Ronis Performance and Tech 4 05-27-2004 05:39 AM
flat tire guyinhershey The ZX-10R 14 05-13-2004 08:46 PM
Daytona tire test take 2. CDRacingZX6R Archives 5 01-26-2004 07:44 PM
Tire re-test this weekend. CDRacingZX6R Archives 9 01-24-2004 09:45 PM
