Gen 3: 2008-2010 Tire choices - Kawasaki ZX-10R.net
post #1 of 16 Old 03-13-2013, 03:55 PM Thread Starter
Newfie Bullet
craig_sez's Avatar
Images: 34
Tire choices
Hey guys.
Hopefully i can get some education from the more experienced guys n gals here..
I currently have a gen 3 zx10r and i love the corsa 3 tires on her..I have done some track days and two track schools but now i wanna try a lil racing so my question is..
Once i get another set of wheels(bike will be doin double duty as street and track bike)should i stay with dot legal street tires or should i look for some slicks...
Love some pro and cons type of advice and if anyone can provide me some links with some tire weights and expected life...A buddy of mine races and he tells me a tire order will be goin in soon so i wanna jump in on a bit of a deal he can get by buying a larger number of tire sets..
Im not lookin to go pro or nothin cause im 48 so im so far past my prime its not funny but i still wanna say i did it and didnt do to to bad,kinda of a bucket list/childhood dream thing..
craig_sez is offline
post #2 of 16 Old 03-15-2013, 07:44 PM Thread Starter
Newfie Bullet
craig_sez's Avatar
Images: 34
48 views and not one comment..sux man..
post #3 of 16 Old 03-15-2013, 08:04 PM
SkyDork's Avatar
Well, I'm not an expert and probably can't help you with your dilemma other than bumping this thread. But I say go for the slicks and see what happens. Yeah, they are expensive, but go for it. You only live once! Yeah, I did the YOLO thing. do it. You can always go back to DOT tires if you don't see any improvement.
#WordCrimes
SkyDork is offline
post #4 of 16 Old 03-15-2013, 08:07 PM
tampamike10r's Avatar
+1
life begins @ 13000 RPMs!!!
2013 WHITE Knight!!!
08 black knight, you will be missed
tampamike10r is offline
post #5 of 16 Old 03-15-2013, 10:12 PM
Cloud 9's Avatar
I have a gen 2? 2007! and with street rubber ridinging in the fast group or even the second fastest group i find street rubber goes off after about 4 to 5 laps ( on my home track which is a tight short track)
now running dunlop Ntec slicks in a Med front and rear times have dropped by 3 seconds a lap with no faid in grip like the street tyres. I'm useing take offs from local qualifying and they might have a dozen hot laps on them then there discarded, i get 6 to 8 track days from them. there half the cost to me compaired to new rubber
Cloud 9 is offline
post #6 of 16 Old 04-09-2013, 12:10 AM
Zx10 Lover!
Fatherdom's Avatar
Send a message via AIM to Fatherdom
I've some good track days using Pirelli pro slicks ..i ride in the b+ group and they have served me well !!.you can average about 4/5 track days out of them depending on how hard you are hitting it ..best of luck!!
Fatherdom is offline
post #7 of 16 Old 04-09-2013, 12:14 AM
Zx10 Lover!
Fatherdom's Avatar
I have also used Pirelli super corsa sp ( standard production) and they work really good also ..
post #8 of 16 Old 04-09-2013, 03:53 AM
or10r's Avatar
Where are you planning on racing because I believe WERA and CCS require a tire "must be DOT approved". If your gonna race I would say get the tire your most likely to race with and spend some seat time learning it.
or10r is offline
post #9 of 16 Old 04-09-2013, 05:18 AM
Nelso's Avatar
This.^^^^
Different tyres require different set ups so you don't want to be switching to a new tyre just before you race.
If you can run slicks, do it. There is a reason why none of the fast guys run street tyres. If you have to run DOT tyres, then stick with that and spend some time getting used to them.
I run Ntecs and they work great for me. I tried Pirellis once when they ran out of Dunlops and I found them to have far less edge grip compared to the Ntecs. I can get 2 race days out of a rear Ntec, but it's starting to move around a bit by the end of a weekend. I can then get another day out of that tyre at a track day before needing to replace it. The front Ntecs last ages. I can get 7 or 8 days out of a front, but I use the UK Ntec on the front as they offer a bit better grip.
Nelso is offline
post #10 of 16 Old 04-09-2013, 07:42 AM
Lee V's Avatar
Originally Posted by Nelso View Post
This.^^^^
Ah, the much deliberated tyre question.
as above, if you can afford the Dunlops then go with them.
Most street/ road tyres are ok ish on a track day untill you try to push them, they dont really like tyre warmers too much as they are not designed to run at such high temps, and as a result the tyre overheats causing loss of grip.
if you want to stick to a fast track tyre but still want the the aid of a tread pattern you can use Dunlop D212GP pro, these are a really good treaded tyre and will stand upto pretty much all you can throw at them and are DOT approved. but do need warmers.
if you make the switch to slicks, Dunlop Kr108/ 106 is the about the best on the market, they give really good feedback through the tyres and dont just let go when they are at the limit of grip( if you can find it that is), they run a really low 22PSI HOT pressure on the rear, 34psi HOT on the front.
if you are a confident rider that can push hard straight out of the gate then give them a go, if not, go with the treaded option, as you may find the slicks make you slower if your not confident enough to push them.
Lee V is offline
Tire choices peedie212 Suspension and Tire Tech 12 01-04-2013 07:53 PM
New car choices The Nam3less The Out House 25 09-21-2011 12:28 AM
Clip on choices JLG0987 The ZX-10R 8 01-31-2011 11:02 PM
MV choices BNninja The Out House 24 06-29-2005 02:42 PM
oil?so many choices,which is best? smittyzx10r The ZX-10R 6 07-21-2004 05:44 PM
