Gen 4: 2011-2015 Syke's zx10 on carburetors? - Kawasaki ZX-10R.net
post #1 of 10 Old 05-27-2013, 06:56 AM Thread Starter
Did I hear right, that Syke's bike "runs partly on carburetors"? I can't believe it. Listen at 1:24
To those who might know, what do you make of this?
gsxrche is offline
post #2 of 10 Old 05-27-2013, 07:29 AM
SkyDork's Avatar
I think you should translate that from British to English. As carburetor is probably just a catch-all term for throttle body in the UK. His bike doesn't run with carburetors.
#WordCrimes
SkyDork is offline
post #3 of 10 Old 05-27-2013, 09:54 AM
SkyDork's Avatar
I can't find anything about the technical specs on this. I find it a bit hard to believe that it uses carbs that have no way of being computer controlled. Or that they could go that far away from the production version. Interesting comment though.
#WordCrimes
SkyDork is offline
post #4 of 10 Old 05-27-2013, 10:07 AM
fireman69's Avatar
All of the electronics require the Throttle body and injectors within. There is much more than the fuel tuning done there. I think he was just using a slang term. Not being technical.
fireman69 is offline
post #5 of 10 Old 05-27-2013, 11:58 PM
Nutter34's Avatar
Maybe they've tuned the response of the fuel injection to mimic carburation. Not be abrupt or super responsive, like some fuel injection systems can be...
You aren't the only ones wondering about that comment...
"You are only young once, but you can stay immature indefinitely."
Nutter34 is offline
post #6 of 10 Old 07-27-2013, 04:06 AM
Check out these fancy Carbs / Injectors..... I don't see the advantage to them other than Lectron trying to hold onto a market share
http://store.schnitzracing.com/lectr...ayabusa-99-07/
Same exact parts as they used on their carbs for decades now minus the float bowl and jets
Gunner is offline
post #7 of 10 Old 07-27-2013, 03:12 PM
BOOSTED's Avatar
He said not bad for a bike that "apparently" runs on carburetors lol! Apparently being the key word here.
2016 Ninja H2 - CANADAS Fastest 1/4 - 8.34 at 169mph - 208.4mph in the mile. Brocks Performance Stage 2 Package, MC Cycle works Intercooler, Full Polished Slash-Cut Exhaust, DNA Filter, PC5, Brocks Lowering Links, Brocks Front Strap Kit, BST Rim, Adams Performance Swingarm 7-11", Zero Gravity Corsa Windscreen, Evotech Radiator Guard, Evotech Fork Sliders, Yoshimura Tail Tidy
2011 ZX10R - SOLD
BOOSTED is offline
post #8 of 10 Old 07-27-2013, 03:30 PM
Engine
Frame
Fuel System:- Fuel injection: φ47 mm x 4 (Keihin) with oval sub-throttles, dual injection
Ignition Digital:- Magneti Marelli
Lubrication:- Forced lubrication, wet sump with oil cooler - Elf
Engine Type:- Liquid cooled, 4-stroke In-Line Four
Displacement:- 998 cm³
Bore x Stroke:- 76.0 x 55.0 mm
Valve System:- DOHC, 16 valves
Transmission:- Wet multi-disc, manual 2.294 (39/17)
Transmission:- 6-speed, return
Final Drive:- Sealed chain
Direct from Syke's website:
http://www.tomsykes66.com/thebike.php
I don't think they can switch from electronic FI to carbs because it would vary too much from the homogulatagatedtatortotpotato version of the bike which would render them unfit to race in SBK. I'd have to read into the regs, so that is just an assumption. And assumption I am 90% confident in ;)
ZX10RArcher is offline
post #9 of 10 Old 07-27-2013, 09:13 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
That's the secret evidently, back to some flat sides and let the men be men
9R to 10R is offline
post #10 of 10 Old 07-28-2013, 10:16 PM
There's no doubt that this motor runs on EFI. I was shocked to find those Lectron's without floats and with injectors installed. They are proud of them as well for what they cost. Who knows there may actually be some advantage to them in some situations when you think about the fact that there's no throttle shaft sticking in the middle of the air flow there's something there even if it's small. The over all length added to the port length appears to the shorter as well.
Gunner is offline
Gen 2: What other zx10 gens body work will fit 2006 zx10 Fatherdom The ZX-10R 1 08-10-2014 09:47 AM
WTT 04 carpenter 3 mil head cam zx10 for 08 zx10 up 3milzx-10 Bikes 4 Sale 7 06-07-2010 09:23 AM
WTT 04 carpenter 3 mil head cam zx10 for 08 zx10 up 3milzx-10 Wanted: Buy or Trade 1 06-06-2010 10:13 AM
2008 ZX10 vs 2009 ZX10 vs 2010 zx10 ghost057 General Motorcycle Discussions 7 12-09-2009 03:59 PM
04 zx10 upgrade: 06 zx10 vs 05 zx6 front brake system Gremlin Performance and Tech 2 08-26-2007 10:02 AM
