Gen 4: 2011-2015 searching Racetrack setup TTX36 - Kawasaki ZX-10R.net
post #1 of 22 Old 10-03-2011, 09:27 AM Thread Starter
Send a message via Skype™ to halfswede
Hi
i just buyed an öhlins rear-shock TTX36 for my GEN4
Front is only the fork oil is changed to öhlins oil.
where do i find some god setup for only racetrack use? I am a strong short breaker, with strong acceleration out of the curve, but i am not extremely fast in the middle of the curve
I am 86 kg.
thanks for your advices
gabor
halfswede is offline
post #2 of 22 Old 10-04-2011, 04:34 AM Thread Starter
Originally Posted by halfswede View Post
Hi
I am 86 kg.
gabor
nobody use ttx36 rearshock? or you just don't wan't to shere secret setup?
post #3 of 22 Old 10-04-2011, 04:52 AM
SBK X's Avatar
I use one but set up is personnel, not a secret.
My setup will vary to yours.
You need a different spring weight depending on your weight.
I suggest you get your sag set up by a professional suspension shop and they will give you base settings to work with, then you can tweak to your liking from there.
Is it at least sprung for your weight?
SBK X is offline
post #4 of 22 Old 10-04-2011, 05:00 AM Thread Starter
thanks for your reply
i got it with 110 kg
than i tested 100 kg
now i am back with 110 kg
post #5 of 22 Old 10-04-2011, 05:45 AM
SBK X's Avatar
I'm 90kg and at my weight the recommended spring is 11.14kg.
I have a 11.7kg/115nm spring which is a little stiff probably but the next choice down was a 10.7kg/105nm which is definately too soft for me.
Stock our Kawasaki was sprung at a low as 9.7kg which is way to low for me and the bike was squating everytime I would get on the gas and tend to run wide.
My spring is a 2 1040-41/115 L3610
The important numbers are the 41 which is the Ohlins rating and the 115which is the nm rating.
110kg seems high as, what's the numbers on your spring?
Have you ridden on that spring yet?
Below is the spring weights worked out for your weight, see the info in bold.
Recommended Shock Spring Rate for 86kg rider for a 2011 ZX-10R is: 10.972 kg/mm (use closest available)
Stock Shock Spring Rate: 9.7 kg/mm (stock)
Available Springs are:
RT SK SPR 58.2x152 8.0kg-79N SRSP 5815080
RT SK SPR 58.2x152 8.5kg-83N SRSP 5815085
RT SK SPR 58.2x152 8.9kg-88N SRSP 5815089
RT SK SPR 58.2x152 9.4kg-92N SRSP 5815094
RT SK SPR 58.2x152 9.8kg-96N SRSP 5815098
RT SK SPR 58.2x152 10.7kg-105N SRSP 5815107
RT SK SPR 58.2x152 11.6kg-114N SRSP 5815116
RT SK SPR 58.2x152 12.5kg SRSP 5815125
RT SK SPR 58.2x152 14.3kg SRSP 5815143
RT SK SPR 58.2x152 15.2kg SRSP 5815152
RT SK SPR 58.2x152 17.0kg SRSP 5815170
RT SK SPR 58.2x152 19.6kg SRSP 5815196
RT SK SPR 58.2x152 21.4kg SRSP 5815214
RT SK SPR 58.2x152 23.2kg SRSP 5815232
RT SK SPR 58.2x152 25.0kg SRSP 5815250
SBK X is offline
post #6 of 22 Old 10-19-2011, 06:04 PM
Fred-R's Avatar
are those parts number ar good for an 3rd gen Ohlins shock or just for the 4th gen?
I'm looking for parts number for a 10.7 kg/mm
Fred-R is offline
post #7 of 22 Old 10-19-2011, 07:00 PM
SBK X's Avatar
Double check that is what you need here below.
http://racetech.com/ChooseVehicle.aspx
Enter your brand, bike and year, then on the next page click on calculate spring rate (it's in big writing accross top of page) put in your weight without riding gear and your bikes wet weight, it will tell you what you need. It should at least give you a good place to start. You really only need the nm rating of the spring which will be the same rating Ohlins or otherwise once calculated.
The numbers at the start will differ as the ones I posted where RT (Racetech), the Ohlins rep you order from will only care about what bike and year and spring rate, they will know the length needed and can suss out the Ohlins code for the spring easy as. Any issues let me know.
SBK X is offline
post #8 of 22 Old 10-08-2015, 05:38 PM
Crescent1101's Avatar
I am having trouble finding the correct spring rate for my Ohlins TTX. I have the ohlins ttx 21041-36/ 105 spring on right now. Does anybody know what weight these are good for? I am 192lbs without gear. I have the option to buy a .95 and 1.0kg from someone.
2009 R6 Racebike - Up for sale!!! Let me know if interested.
2013 ZX10R- SOLD
2008 ZX10R- SOLD
Crescent1101 is offline
post #9 of 22 Old 10-08-2015, 06:33 PM
Mantis_Tech's Avatar
105 is too soft, you would be happier with a 110 if you have an attack ..kyle... link, or a 120 if you don't plan on getting a link. I'm sure LDH can chime in here. My opinion is just that, an opinion, I am 202lb unsuited, I wasn't happy with the 130 , the 110 was adjustable to give me 28mm sag , but I like the way the 120 feels best, I do not have a link
Mantis_Tech is offline
post #10 of 22 Old 10-08-2015, 07:13 PM
A Squids Life's Avatar
I am 88kg naked or about 95kg fully leathered/booted up. I run a 120nm/12kg spring on my gen 4 TTX. I find this to be very good. Sounds like you are in a similar weight range to me. With the 11kg spring and max preload my sag was 47mm. I use a stock link and have raised the rear by around 6mm on the shock. The bike feels stable and planted cornering and doesn't wallow accelerating hard out of corners, sounds like this is your style of riding also.
A Squids Life is offline
2008 Racetrack Setup Information Manual tasos Performance and Tech 15 02-16-2011 01:12 PM
New Racetrack in Colorado .. Felix el gato Track 9 07-16-2008 03:46 PM
New Racetrack in South Jersey Skip114 Track 6 01-15-2007 09:15 PM
pocono racetrack video Zxrider Pictures and Videos 4 05-14-2006 02:23 PM
Kawasaki's NEW racetrack extremelean The Out House 9 08-10-2005 10:24 PM
