rear sprocket, how many teeth???? - Kawasaki ZX-10R.net
post #1 of 20 Old 03-13-2006, 05:00 PM Thread Starter
BANNED
i am running a 15 tooth front with the stock 39 rear. im getting 1.52 60 ft. how high should i go? i was told to go 42, but i want other opinions.........
mikebar4 is offline
post #2 of 20 Old 03-13-2006, 07:57 PM
How low, what length, what modifications?
heavyd is offline
post #3 of 20 Old 03-13-2006, 08:25 PM Thread Starter
BANNED
the bike is 59" , lowered and strapped, full muzzy, pcIII, and the 15 tooth front sprocket. i was told by the previous owner that the bike has seen 9.47 with a 140lbs rider....im gettin 10.0s. but i have only ran it twice....
mikebar4 is offline
post #4 of 20 Old 03-13-2006, 08:31 PM
Most guy's that run the 10's in Prostar (3" off the ground and stock wheelbase) run 15/39. I have never ridden a lengthened bike, but Norm Jackson posted that he runs 15/42 on his bike that is close to 59".
heavyd is offline
post #5 of 20 Old 03-13-2006, 09:16 PM Thread Starter
BANNED
yeah that guy can ride...thats what im prob gonna do....i dont think that will be all that bad when im street ridin, as far as top speed goes.
mikebar4 is offline
post #6 of 20 Old 03-14-2006, 02:48 PM
GARSZX10R's Avatar
Send a message via AIM to GARSZX10R
Im 140lbs and have seen 9.61 with a 15/39, lowered and strapped set-up......everything else stock down to the airfilter. I don't think I would go over a 41 if you going to use the same set-up on the street. the 15 will cut your top speed down into the 160's.....that's what it did to mine and that was with the 39 on the rear.
Also, I don't know how your cutting 1.52 60's and still not in the 9's.....that doesn't make any sense to me. My 9.61 was on a 1.55.
From the Stern Show "Ralph's the only guy I know that goes home and masterbates to reruns of will and grace"
GARSZX10R is offline
post #7 of 20 Old 03-14-2006, 07:47 PM
If you are getting 1.52 60' times you should be able to go 4.0 330's and even with stock horsepower i would guess 9.50's.
heavyd is offline
post #8 of 20 Old 03-14-2006, 08:14 PM
moonzx10's Avatar
what's your wieght?
moonzx10 is offline
post #9 of 20 Old 03-14-2006, 08:31 PM Thread Starter
BANNED
im 200 lbs. i cant understand it either.. i just purchased an air shifter because the prob might be my shifting. i have cut in the 1.50s more than one time. im thinking of trying a 41 tooth. when i do ride on the street, im not real big on trying my top end out too much. isnt a stock chain a 525? does anyone have a 41 tooth rear????
mikebar4 is offline
post #10 of 20 Old 03-14-2006, 08:41 PM
Send a message via AIM to Cycle Concepts
i have a 41 rear for the zx10...give me a call if you need it...thanks!!
dwayne
Cycle Concepts is offline
Ok, my front sprocket was easy... -install with pics El Diablo Performance and Tech 122 04-02-2015 03:51 PM
520 Rear Sprocket 40T Sprocket Specialists bluedevil Parts, Gear and Accessories 5 12-17-2005 09:21 AM
Installing new rear sprocket - what side? circusnuts Performance and Tech 10 09-02-2005 09:47 AM
39T to 42T Rear Sprocket Conversion - HELP! * bchild Performance and Tech 17 05-16-2005 12:45 PM
Ok, my front sprocket was easy... El Diablo How To... 1 02-07-2005 11:10 PM
