Race tech shock revalve - Kawasaki ZX-10R.net
post #1 of 7 Old 06-13-2008, 05:50 PM Thread Starter
edgeflyer's Avatar
O.K. I know I should buy a new 1000 dollar shock, but I need to spend $$$$ on the front also so has anyone revalved a rear shock and was it an upgrade,or a total flop and waste of money? also is racetech front valves or ohlins kits prefered amung racers?
edgeflyer is offline
post #2 of 7 Old 06-13-2008, 07:31 PM
green_zx's Avatar
Send a message via AIM to green_zx
Look up member greenblur. He had his stock front and rear revalved at gp suspensions under $1K I believe. As far as I know he is pleased with their work and the results. I was at a trackday with him and he is mos def faster than last year at the same track.
green_zx is offline
post #3 of 7 Old 06-16-2008, 08:57 PM
P 51 Jockey's Avatar
I went with all Ohlins, just cause I wanted to try their stuff. The stock front end comes with 1kg springs, but the air gap needs to be re-set. This is your cheapest option. I have heard that Racetech's newest cartridges are working well for WERA racers, as well as GP Tech, and this is your second cheapest option. Ohlins, well, you know.....
As for the rear shock, the stocker isn't worth the labor. At least try to find a Penske or Elka. You can't skimp on the rear, but you can get better results in the front without spending as much.
P 51 Jockey is offline
post #4 of 7 Old 06-17-2008, 07:32 PM
roadracer98's Avatar
P 51 is right. You have really no choice for the rear if you plan on consistent performance.
The rear shock on the 08 is good for 4 hot laps then it turns to crap as most OEM shocks do . I will be doing the Ohlins in the rear and prolly the Ohlins parts in the front end as well if I decide to go racing full time.
2010 BMW S1000RR- 2008 CBR1000RR
roadracer98 is offline
post #5 of 7 Old 06-17-2008, 11:00 PM
Also, my suspension guru told me that the damping needles need more of a taper cut in them as they don't have much range of adjustment. You will probably have to do this with any fork re-valve parts you choose to do. The stock part just sucks as it is supplied from KYB.
post #6 of 7 Old 06-17-2008, 11:28 PM
BANNED
Yeah dont wast your $$ on the stock crap! find a used Penski or Ohlins and get it re built!! as for as fork kits I have the Traxxion AK-20's and there great!! and the Ohlins 25mm I was told are the shit!!!
thehate. is offline
post #7 of 7 Old 06-18-2008, 04:02 PM Thread Starter
edgeflyer's Avatar
O.K. ya'll are baaad influences. I ordered a 3 way elka for the rear and the new g2r comp valves, HFR rebound valves, racetech springs, racetech top out springs, superslick oil, and seals of course for the front. now anyone want to sponcer a wannabee racer?
FS: Race Tech Shock for '05/'06 ZX6R IcePick06 Parts, Gear and Accessories 0 09-23-2007 03:44 AM
Race Tech biker_larry1000 Performance and Tech 12 03-06-2007 10:27 PM
Race Tech Shock Clock louemc Performance and Tech 4 12-23-2006 02:15 PM
Aftermarket shock/forks vs race-tech revalve/respring = ? Ronis The ZX-10R 11 09-25-2004 10:08 AM
Full system & pcIII vs. ohlins shock and race tech ELRWFO The ZX-10R 2 05-15-2004 10:22 PM
