Race Bodywork melt/fire issues 08 ZX10R - Kawasaki ZX-10R.net
post #1 of 29 Old 08-14-2009, 06:16 AM Thread Starter
I had my new set of Hotbodies (the lower) catch fire at Barber last weekend on my 08 ZX10R. Never had this issue with Hotbodies before. I had my exhaust in full header wrap and exhaust wasnt touching. What race body are you using and what heat precautions are you taking? I am currently running stock headers with cat bypass mid pipe into Hotbodies MP slip - on.
Corvette95 is offline
post #2 of 29 Old 08-14-2009, 11:12 AM
Я - Ребенок Люциферов
Vonstallin's Avatar
Images: 16
I replied on the WERA board..but the stock system is uber hot and no good way around it.
You cant bypass the cats on this system vs the 06's. The cats are made into the lower header section so you will have to gut it at the very least.
I have the same set up for the most part and its ok on heating, but the endurance race melted my plastics. also you will have to trim down the plastic up front a few inches. I posted pics on the wera board on a Hotboies thread. I will try and look it up.
Id say gut the cats that are in the header, trim the front of the body work down some and double wrap the pipes.
You can see how much I cut down in this picture. The original body work meets up right under the radiator. The stock headers bow forward and put it too close to the body work while the after market headers are straighter downward away from the bodywork.
I still fun stock exhaust, gutted cats in the air box, boom box cats removed and M4 slip on. For trackdays and race sprints its fine, but 6 hour endurance fried everything.
CCS/ASRA Novice 325 | WERA Novice 325 | The Nightmare of Summit Point
2016 ZX10R ABS | 2011 ZX10R | 2019 KTM 250XC-F | 2020 ZX10R coming soon....
GunnRunnaz.com|Gunn Runnaz on FaceBook
Vonstallin is offline
post #3 of 29 Old 08-14-2009, 11:14 AM
Vonstallin's Avatar
Images: 16
PS: my 06 caught fire also and this one smoked real bad. ITs too much heat from the heavy metal construction of the stock Ti pipes.
Also you might notice your motorcycle runs hotter.
on the 06 I put a full Akropovic on and no more fires and the bike temps went back down.
post #4 of 29 Old 08-15-2009, 08:31 AM
OMG Look at that squid!!
trackaddict's Avatar
Images: 51
Use Dynamat on the inside of the lower. I did and it took care of the issue.
Because wheelie!!!
17' Honda 1000RR SP - 08' Hypermotard 1100s
16' ZX10R - SOLD
14' Ducati Monster 1200S - SOLD
13' RSV4-R - SOLD
My ZX10R's 11' - 08' - 07' - 05' - 04' - ALL SOLD
Miss my Black 04' the most!
Never enough money, never enough time!
trackaddict is offline
post #5 of 29 Old 08-16-2009, 01:19 AM
Vonstallin's Avatar
Images: 16
I have 3 layers of dynamat it did stop the fire, but it still smokes. well only for long races (30 minutes or more)... but should be fine for sprints or track day sessions.
post #6 of 29 Old 08-16-2009, 09:11 AM
Images: 51
Weird. I've had the heat issue on the 04 and 08 ZX10 track bikes for sure. I finally used dynamat and had no more trouble. Must be the variances between different bodywork. I use the cheap stuff cause I tend to crash (to much!) lol
Because wheelie!!!
16' ZX10R - SOLD
13' RSV4-R - SOLD
post #7 of 29 Old 08-19-2009, 10:30 AM
Look for gold heat reflective foiling. Cover the problem areas, and it should help reflect heat away from your parts.
Xevuhtess7 is offline
post #8 of 29 Old 08-19-2009, 10:43 AM
spikespiegel's Avatar
Send a message via AIM to spikespiegel Send a message via Yahoo to spikespiegel
i do trackdays and have had the 'melting' issue on my lower panels (i use catalyst composites) on my stock exhaust. I am ditching the stock exhaust for a full system and am gonna heat shield the lower to see what happens next, no doubt, it is the cat's fault
spikespiegel is offline
post #9 of 29 Old 08-21-2009, 10:41 PM
bullwinklelol's Avatar
I used foil sheilding with 1/4 inch insulation as backing, I ran 6 20min sessions last weekend and my hot bodies did fine before heat sheilding it melted off my paint and smoked somthing feirce
08 ZX10R
woodcraft covers, crg shorties, brembo master, galfer lines, Shogun sliders, Vortex rearsets, m4 gp, hotbodies glass.
bullwinklelol is offline
post #10 of 29 Old 10-14-2009, 02:12 PM
Vonstallin's Avatar
Images: 16
same here, i run hot bodies on the 06 and 08...
Even after installing the Akra system it burns thru 2 layers of dynomat in one small spot.
Look and see black burnt spot.
The bigger spot was how much got burnt when I had stock system and it would catch on fire.
I still think that the heavy Ti on the stock stuff generat to much heat.
Race bodywork help!!!!!!! DB Performance and Tech 4 03-30-2009 05:48 PM
04-05 ZX10R painted race bodywork banzai Parts, Gear and Accessories 4 12-27-2008 05:03 AM
ZX10R Race Bodywork, New Paint! Blink180Wilhelm Pictures and Videos 11 09-22-2008 11:00 PM
04/05 ZX10r RACE BODYWORK nelly250 Wanted: Buy or Trade 0 04-22-2007 11:10 PM
Race Bodywork bikerscum Race and Stunt 4 07-17-2004 10:10 AM
