Question - Kawasaki ZX-10R.net
post #1 of 3 Old 03-09-2006, 06:01 PM Thread Starter
bragg10r's Avatar
Question Question
Hello all...Have not been on in a few days.....Got a question, took the 10 out today to work, and when coming home, I took a curve pretty steep, the FI light went on, then after about 10secs went out again. Brought the bike home, looked in the tank, looks pretty full, not all the way, about 1/4 tank, moved the bike to one side and it did it again, then went out again. Is this just natual or is there a problem???? Thanks...
Bragg...
"Best" (Time Slip Proof) Run so far :
60ft:1.7
330ft: 4.5
1/8: 6.7 @ 113mph
1/4: 10.2 @ 142mph
bragg10r is offline
post #2 of 3 Old 03-09-2006, 06:02 PM Thread Starter
bragg10r's Avatar
And I Filled it up before I went to the track, drove it to the track (15 Miles one way) Made about 12 Passes at the Track, drove it home, took it to work 5 Miles one way....So I'm thinking it is just low. I just have a Muzzy Slip on.....
60ft:1.7
330ft: 4.5
1/8: 6.7 @ 113mph
1/4: 10.2 @ 142mph
bragg10r is offline
post #3 of 3 Old 03-10-2006, 06:17 PM
Maybe a loose connection. Have you done any work to it recently? Low fuel shouldn't cause an FI light. Might want to check to see if it threw a code.
CanyonCarver is offline
Question for those with Gilles rearsets??? deputydog95 The ZX-10R 9 04-18-2008 07:10 AM
Air Box Question DarkTari Performance and Tech 10 09-09-2005 07:22 AM
oil question zfactor2004 Performance and Tech 16 07-21-2005 08:21 PM
Muzzy (Hyperpro) damper install question YSR50 Performance and Tech 3 07-04-2005 01:05 AM
A Question for you Brains out there - calling all PC3 nerds.JK GREENDEL Performance and Tech 2 04-23-2005 07:13 PM
