Prepping street bike for a track day?? - Kawasaki ZX-10R.net
post #1 of 8 Old 04-30-2006, 07:00 PM Thread Starter
Hello ZX-10R racers. I'm going to be doing my first rack day experience shortly. I wanted to prep the bike as best I could with respect to the lights, mirrors etc.
What is the best thing to do with the rear tail, brake, signal light assembly? Can I just remove the entire thing and use my Targa fender eliminator pieces to cover up the gaps/holes left from removing the entire mud flap? Can you just leave the wire harness with nothing connected to it if you remove the rear light assembly or does something have to be connected to it? What about the head lights, is there a fuse I can remove so they wont be on because they will most likely be taped over?
Mirrors: are the bolts/nuts an integral part of the upper fairing? Will it be compromised if they are removed?
Any other suggestion are much appreciated as to prep. The coolant thing is a non issue and the bike doesn't need all sorts of safety wiring. Supercorsa's are going on it and the bike has a Scotts damper.
Thanks in advance
fun2fly is offline
post #2 of 8 Old 04-30-2006, 07:57 PM
Big Daddy's Avatar
Images: 38
this might help.
https://zx-10r.net/forum/showthread.php?t=12752
Big Daddy is offline
post #3 of 8 Old 04-30-2006, 09:52 PM
Green Hippie
treyzx10r's Avatar
Originally Posted by Big Daddy
ahhh the ever neglected search function once again BD to the rescue
VAE VICTUS!
treyzx10r is offline
post #4 of 8 Old 04-30-2006, 10:02 PM
Post Whore
Older Guy's Avatar
Ok...some more suggestions:
Drain the water tank and replace with Water Wetter...make sure you purge the air from the system too...
Remove the fuses for the headlights and taillights...get some blue painter's masking tape for the headlights, taillights and turn signals...
And remove the little rubber piece from the mirror support that is attached to the fairing...underneath it, you'll find an allen bolt that safely removes the mirror stalk without screwing around with the fairings...
Check the track rules for safety wiring needs...
Make sure you have GOOD tread left on your tires and they are at the correct air pressure.
See other thread for parts and things you need to bring and do...
Good luck and have fun...post up some pictures....
Older Guy is offline
post #5 of 8 Old 04-30-2006, 11:15 PM
Big Daddy's Avatar
Images: 38
i have no life so why not help eah.
post #6 of 8 Old 05-01-2006, 07:05 AM
hangman39's Avatar
http://www.edbargyracingschool.com/kit.htm
Here is a kit you can get that has what is needed to safety wire has all the pre-drilled bolts.
http://www.sportrider.com/ride/146_0...ion/index.html
Here is a good write up in Sportrider
hangman39 is offline
post #7 of 8 Old 05-01-2006, 08:37 AM
Hillbillie Mod
hillcountry10r's Avatar
Images: 31
Painters tape on the lights.
if youre changing your fluid, be sure to burp the system.
put a lot of air in your tires before you get there so you can be sure to have the right psi in your tires when you're ready to ride.
James 3:7,8
hillcountry10r is offline
post #8 of 8 Old 05-01-2006, 01:36 PM Thread Starter
Thanks for your contribution BD, Hill, OG, Hangman39
Trey
fun2fly is offline
Parting out: 04 ZX10R track bike afm223 Parts, Gear and Accessories 41 10-31-2005 08:15 AM
Track Bike Suggestion pongo Race and Stunt 22 10-16-2005 12:47 PM
Motor Sport Ranch Track Day 03/14/05 hillcountry10r Race and Stunt 7 03-22-2005 03:47 PM
RedElk's ZX10R Ride and Adventure review swft The ZX-10R 11 03-11-2004 01:24 PM
Some driving test`s with the ZX-10R Mike_P Netherlands Archives 16 01-07-2004 12:10 PM
