please help stop spinning - Kawasaki ZX-10R.net
post #1 of 11 Old 07-13-2006, 10:02 AM Thread Starter
05 zx 10 lowerd all the way in rear, shinko u soft tire, -2 in front, 7 inch over, full ti force exhaust power commander, spin through all gears with 16 lbs air pressure even at track. can someone who drag races help me set up my suspenison
1st10ever is offline
post #2 of 11 Old 07-13-2006, 10:09 AM
Big Daddy's Avatar
Images: 38
perhaps you'll get help in this section.
Big Daddy is offline
post #3 of 11 Old 07-13-2006, 10:18 AM
FAF
Rent this space
Sometimes if you get a lot of squat when applying power you can suffer from lack of rebound damping making the back of the bike stand up again and the rear gets light, add more rebound.
Sometimes you dont get enough squat and the bike will bounce the tire up the track never making good traction , reduce compression.
Normally to get more grip you need to run a soft spring setup but this also will suck up some power as you are not only applying it to forward motion but also downward, the best spring you have is in the sidewalls of the rear tire though and playing with tire pressures is probably the best solution , you have a multitude of choices for getting grip.
Try going full stiff on everything on the rear and wind up the spring, this will let the tire do the work, then play with pressures, if that doesnt help then start to go softer on the rear compression damping.
How heavy are you ?
FAF is offline
post #4 of 11 Old 07-13-2006, 10:58 AM
eric's Avatar
get a air shifter. i was doing the same thing until i started using my air shifter.
eric is offline
post #5 of 11 Old 07-14-2006, 12:27 PM Thread Starter
yea
iam bout 180 lbs i have tried the stiff solution thats not going to work so now i will try softer spring but how do i need to set the comression and rebound? ps oh yea thanx for the help so far
post #6 of 11 Old 07-14-2006, 12:59 PM
FAF
Rent this space
1st10 , if you have wound down the spring perch then try using stock settings
to start with 1.3/4 turns out for rebound (bottom adjuster) and 3 turns out for compression (top adjuster) , this should be a good baseline as the settings are for 150lb rider, so you will be soft to start.
Also , now your sag is lower it should transfer a little more weight to the rear of the bike as the rake has changed.Start working up the scale with adding one sweep of bump(compression) to 2 sweeps of rebound and see how that goes.
One more thing that has just struck me, it has happened a couple of times to me in the past(a long time ago), my turbo bike would spin the wheel inside the tire , can you feel the bike stepping out or does it feel a little like clutch slip ??
FAF is offline
post #7 of 11 Old 07-14-2006, 01:01 PM
FAF
Rent this space
PS.
Take notes , so you dont get lost.
FAF is offline
post #8 of 11 Old 07-15-2006, 10:22 AM Thread Starter
Thanx
yea iam covering ground but this is whats happing when i leave around 6500 its fine but as soon as i go into 2nd gear smoke the rear tire every time at the track on the street no matter how i adjust the rebound or comp.with 16lbs of air in shinko u-soft tire
post #9 of 11 Old 07-15-2006, 10:43 AM
eric's Avatar
buy a air shifter. its stop my spinning even with the stock tire on it.
eric is offline
post #10 of 11 Old 07-15-2006, 01:17 PM
what wheel base U have now?
PuertoRicoZX10 is offline
I can stop whining, I GOT A BIKE! dr_wookiee The Out House 23 03-05-2006 03:39 PM
Stop e mailing me!!!! 10 speed ZX-10r.net Site Help, Suggestions and Questions 10 01-12-2006 08:56 AM
vw ad on how to stop suicide bombers sabersaw30 Pictures and Videos 3 01-22-2005 06:02 PM
a fast way to stop a bike cain772 Pictures and Videos 3 12-18-2004 06:25 PM
Should dealers stop selling ZX10Rs??? Steamin The ZX-10R 14 08-06-2004 06:04 PM
