OHLINS KA345 46 PRXLS Shock Need Advice 1st Gen - Kawasaki ZX-10R.net
post #1 of 6 Old 09-21-2013, 10:43 AM Thread Starter
GREENDEL's Avatar
Question OHLINS KA345 46 PRXLS Shock Need Advice 1st Gen
Hey Guys I have a 2004 10R with the front Ohlins 20mm Piston Kit done by Thermosman, and a brand new Ohlins KA345 46PRXLS rear shock . I have the geometry set to my liking coupled with Thermosman's advice. The front is perfect. The problem is that this rear shock feels UBER stiff even though my Static sag #s and Rider Sag #s are Within normal limits per Ohlins recommendations. - The rear squat characteristics are incredibly stiff. It really makes little difference with the high and low speed compressions settings. I previously had the stock shock Rebuilt and revalved with Race tech spring prior to Buying the Ohlins, and even though the Eye to Eye length is the same this Ohlins feels super stiff compared to the rebuilt stocker. I swapped my 95NM spring for a 90Nm spring and it still feels stiff. 95NM was recommended for my weight. I even had the Installed preload of 12mm adjusted to 5mm. Yep still stiff...
Is this normal for this shock on this model???? Anyone besides me have this experience????
Any input is appreciated.
Thanks in advance.
What did she say? - She Lida da soup!!
GREENDEL is offline
post #2 of 6 Old 09-21-2013, 11:51 AM
or10r's Avatar
Man that sounds weird. This would be a shot in the dark but you didnt over tighten your chain did you? Hopefully some guys like fireman69 and Mr FlipFlops will see this. Both guys are racers and have helped me sort through a couple of suspension questions I had.
or10r is online now
post #3 of 6 Old 09-21-2013, 12:13 PM
I'm no suspension guru but I wonder if a lighter weight oil would benefit you any.
Need OEM parts? Discounts available on all Honda, Suzuki, Yamaha, and Kawasaki factory parts. PM me.
Kawazuki is offline
post #4 of 6 Old 09-21-2013, 01:34 PM Thread Starter
GREENDEL's Avatar
Thanks for the replies- will keep both comments in mind!
GREENDEL is offline
post #5 of 6 Old 10-08-2013, 01:58 AM
I had the same trouble with a ohlins on my zx14 tried a softer spring still stiff .I went back to correct spring it just needed a revalve that fixed the problem.
shakey is offline
post #6 of 6 Old 10-28-2013, 09:12 PM Thread Starter
GREENDEL's Avatar
Smile
Thanks Shakey for the advice, will live with it for the time being and when I send it in for the service, I'll have them check it out.
GREENDEL is offline
GEN 2/3: Ohlins 46 PRXLS Rear Shock ZiXeR Parts, Gear and Accessories 12 03-22-2013 02:32 AM
Gen 1: Wanted: Ohlins KA345 Shock sixstring Wanted: Buy or Trade 4 03-03-2013 10:41 AM
Gen 1/2 Ohlins PRXLS shock on a Gen 3? caboose Performance and Tech 13 09-24-2011 05:54 PM
FS: 06-07 Ohlins Shock PRXLS green_zx Parts, Gear and Accessories 8 01-11-2009 08:36 PM
Ohlins Zx-6r Prxls Shock zx10Rocket Parts, Gear and Accessories 0 10-16-2007 03:43 PM
