New brake pads break-in - Kawasaki ZX-10R.net
post #1 of 14 Old 03-01-2012, 09:47 AM Thread Starter
Does not drive into smoke
El Zilcho's Avatar
How do you break-in new pads on a track bike? Do you do anything special, or just ride it with extra care?
El Zilcho is offline
post #2 of 14 Old 03-01-2012, 10:06 AM
SkyDork's Avatar
It depends on the pads, but I've always done a pad bed-in procedure that involved a series of progressively harder stops. 10 of them to be exact.
Get the bike up to speed and do a series of stops from like 50 or 60mph. This will get the brakes hot. Start off with 5 medium power braking efforts to a complete stop. Then drive for a while to give the brakes a chance to cool down. Then repeat the process using maximum braking for another 5 runs. This should bed them in and you'll be good to go.
#WordCrimes
SkyDork is offline
post #3 of 14 Old 03-01-2012, 10:08 AM
SkyDork's Avatar
Here's some more information
http://braketech.com/index.php?optio...talk&Itemid=69
#WordCrimes
SkyDork is offline
post #4 of 14 Old 03-01-2012, 10:12 AM
SkyDork's Avatar
More info, related to cars, but still....
http://www.tirerack.com/brakes/tech/....jsp?techid=85
#WordCrimes
SkyDork is offline
post #5 of 14 Old 03-01-2012, 10:17 AM Thread Starter
El Zilcho's Avatar
Many thanks! That's good stuff. I was actually planning to use the spray cleaner before I read the first link.
Thanks again. Tried to rep, but need to "spread more reps first"..
post #6 of 14 Old 03-01-2012, 01:19 PM
Post Whore
-Op-'s Avatar
this does not apply to street right? I mean, some of it yes, but its still a little different? Like, clean em off and just go easy on the pads for like 100 miles and then get on it harder?
-Op- is offline
post #7 of 14 Old 03-01-2012, 02:14 PM
or10r's Avatar
Im pretty much with Skydork.
Heres my routine.
30-0 easy x 5
40-0 medium x 5
60-0 hard x 10
Im not sure where I learned it this way or even if its right but its has worked for me so far.
or10r is offline
post #8 of 14 Old 03-01-2012, 02:34 PM
SkyDork's Avatar
Honestly, I think it's more important to do for street riding since the brakes rarely get used as hard as they doing in racing. Especially new pads and/or rotors. I've always bedded-in new pads on this way.
#WordCrimes
SkyDork is offline
post #9 of 14 Old 03-01-2012, 02:55 PM
SkyDork's Avatar
Heres my routine.
30-0 easy x 5
40-0 medium x 5
60-0 hard x 10
Yeah, that's close to my procedure as well. But I go from a higher speed to prolong the stopping.
50mph-0 easy x2
60mph-0 medium x5
60mph-0 hard x5
Then I go out and cruise for 10-15 mins to cool off the system and then repeat the medium and hard sequences.
Also, it's important to note that when each stop is complete, it's really not to a full stop. More like a rolling stop. I don't put my feet down. I just accelerate away and start it again. I don't like the pads clamped to the rotors in one spot for any length of time while they are hot. So it's more like 50mph down to 2mph and go.
#WordCrimes
SkyDork is offline
post #10 of 14 Old 03-01-2012, 03:41 PM
Post Whore
-Op-'s Avatar
when I change pads, then Ill give this a shot and see what it does. thanks guys!
-Op- is offline
Need OEM Break Pads kawiiiiii Parts, Gear and Accessories 0 05-22-2011 06:50 PM
Brake pads question, zx14 calipers, will zx10 pads fit xx8055NIACxx Performance and Tech 6 04-05-2010 06:26 PM
anyone have experience with EBC break pads? cdnzx10r Performance and Tech 3 04-09-2008 10:52 AM
Zx-6 brake pads much thinner than ZX-10 brake pads Musikkant54 Performance and Tech 1 08-31-2007 12:54 PM
Break-in of Pads? zx-10r203 Performance and Tech 5 01-29-2007 10:17 PM
