Moving HP lower in RPM range - Kawasaki ZX-10R.net
post #1 of 5 Old 06-16-2012, 01:43 PM Thread Starter
Is there a cam or way to move my peak HP closer to my peak torque and carry the peak HP out further to max RPM with out the HP dropping off at top RPM?
Quantrill is offline
post #2 of 5 Old 06-16-2012, 01:55 PM
ZXRANDY's Avatar
Moving peak HP around it all about degreeing your cams.
Garth has a writeup somewhere on degreeing cams.
Im not quite sure what you want is possible though, that and I just have no idea.
ZXRANDY is offline
post #3 of 5 Old 06-16-2012, 03:29 PM
Post Whore
-Op-'s Avatar
if you were to shift the way the bike makes power, you will lose some in the other areas. IE shifting towards more midrange will usually cost you topend. Unfortunately you cannot have it all
-Op- is offline
post #4 of 5 Old 06-16-2012, 03:49 PM Thread Starter
Here is Garth's article on how to degree cams is this the one your talking about or is there another article he has wrote on this subject?
https://www.zx-10r.net/forum/showthread.php?t=84083
post #5 of 5 Old 06-18-2012, 11:13 AM
beenthere's Avatar
An old trick for a bit more midrange punch is to set valve clearences on the larger end of their tolerences. Valves stay closed just slightly longer, capturing more mixture, very slightly boosting compression...viola mo' midrange
beenthere is offline
Gen 3: Bogging in lower RPM range rainking12 The ZX-10R 22 03-07-2012 05:59 AM
Who wants 16hp in there mid range? Gravesport.com Performance and Tech 57 09-22-2011 10:10 PM
A little fun at the range today ronnulph Pictures and Videos 16 06-24-2010 09:38 AM
Moving cross country, moving service recommendations? CatchMe4G63 The Out House 1 05-05-2009 09:52 AM
price range for an 03 ZX-6RR ? TR-10 ZX-6R & ZX-6RR Archives 3 04-05-2007 01:01 AM
