Gen 1: 2004-2005 Lowering Links - Kawasaki ZX-10R.net
post #1 of 10 Old 02-01-2012, 01:47 AM Thread Starter
Post Whore
-Op-'s Avatar
Lowering Links
Need opinions on lowering links. Im in the process of stretchin out my Gen 1. Im gonna go approx. 6" over. Ride it daily on the street everywhere, but Im a weekend drag racer and want to really drop my times. I sorta have an idea as far as lowering it is going to go. Im gonna drop it 10mm in the forks and a little bit in the rear and just strap the shit outta the front to get it low at the strip and then use links to get the rear the rest of the way.
What I want to know is what everyone thinks about different brands/styles of links. Personally, Im heavily leaning towards Soupys. I know they are slightly overkill, but it was so I could drop the height when I got to the strip, but keep it raised up when Im street riding. Thoughts?
-Op- is offline
post #2 of 10 Old 02-01-2012, 10:11 AM
zx racer's Avatar
you could just pick up set of 3 hole lowering links and put the bolt in the 2nd hole which is only a 2 inch drop and still be plenty streetable.
05 ZX-10R SWB.
zx racer is online now
post #3 of 10 Old 02-01-2012, 10:28 AM Thread Starter
Post Whore
-Op-'s Avatar
^true too. I just liked the idea of being able to adjust completely as well. Im mostly looking for opinions on brands and materials they are made from. Stuff to consider when buying them.
-Op- is offline
post #4 of 10 Old 02-01-2012, 12:20 PM
BlkCasper's Avatar
I bought the Soupys fully abjustable for my 06 Zx10. Very happy with them as i was frequently changing my setup from stretched to stock lenth. I got the 1 in extra lenth ones wich are a little to long because when switching back to stock wheel base bike is still 1 in lower than stock. Greatest benifit is that you don't have to jack up bike and remove link bolts to chage ride hight. Just loosen up lock nuts and twist away. Some type of lenth indacator would be a big help though to get both sides even. I just use a measuring tape to verify both sides are at correct lenth.
I have over 15k miles on bike,including drag strip, road race track days, commuting, and weekend blast up my favorite twisty back roads with them installed and no issues.
BlkCasper is offline
post #5 of 10 Old 02-01-2012, 12:32 PM
NinjeR's Avatar
I used to be able to get these made for cheap in NY but now I have no contact with the person any more, but these gives me a lot of adjustability and once you remove the link once, you're able to change your height in about 15 mins afterwards.
NinjeR is offline
post #6 of 10 Old 02-01-2012, 02:30 PM Thread Starter
Post Whore
-Op-'s Avatar
Thanks for the input on this guys! All of it really helps. Casper, how was installing the Soupys?
NinjeR, do you know who makes them or what material are they made from?
-Op- is offline
post #7 of 10 Old 02-01-2012, 02:52 PM
zx racer's Avatar
the adjustable ones are nice but the 3 hole ones will do the job. only take mins to lower the rear down and the ones i have are made out of billet aluminum.
05 ZX-10R SWB.
post #8 of 10 Old 02-02-2012, 02:05 PM
NinjeR's Avatar
T7075 or T6061 aluminum
NinjeR is offline
post #9 of 10 Old 02-02-2012, 07:05 PM
blink.'s Avatar
I will trade you 3 hole lowering links for your stock links.
blink. is offline
post #10 of 10 Old 02-02-2012, 07:22 PM Thread Starter
Post Whore
-Op-'s Avatar
sorry, I want to keep the stock ones too. If I change my mind though, youll be the first to know.
-Op- is offline
adjustable kickstand, lowering strap kit, lowering links Satan Parts, Gear and Accessories 5 10-01-2010 10:35 AM
1st Gen Lowering links PearlOrange04 Wanted: Buy or Trade 0 03-01-2010 02:32 PM
F.S. 04-05 10r 3-way lowering links hesaves0211 Parts, Gear and Accessories 4 07-12-2007 12:33 AM
lowering links? raulzx10r Performance and Tech 6 06-19-2007 03:34 PM
Lowering links ???'s toolucky Performance and Tech 7 06-18-2007 07:08 PM
