jumping out of gear - Kawasaki ZX-10R.net
post #1 of 6 Old 04-10-2006, 09:13 AM Thread Starter
BANNED
jumping out of gear
ran my 04 10 yesterday. got the best time i ever ran too. my problem is, when i used my airshifter, the bike would pop out of gear sometimes. i just installed a 42 tooth sprocket in the back and an aircompressor for my airshifter. i ran about 95 psi in my air tank. when i foot shifted, it done fine. any suggestions??
mikebar4 is offline
post #2 of 6 Old 04-10-2006, 06:24 PM
bragg10r's Avatar
is your air shifter not fully engaging?? Maybe not pulling it all the way up? Or does it happen after it is already in gear????
"Best" (Time Slip Proof) Run so far :
60ft:1.7
330ft: 4.5
1/8: 6.7 @ 113mph
1/4: 10.2 @ 142mph
bragg10r is offline
post #3 of 6 Old 04-10-2006, 07:03 PM
rated zx's Avatar
Yep, airshifter has to be at 120-130 psi to shift on any bike. It tells you that in the instructions. Besides I've ran them on a few different machines, all of which required at least 120 to work.
HACKSTALL RACING AND ENGINEERING (H.R.E)
rated zx is offline
post #4 of 6 Old 04-11-2006, 12:18 AM
zx10lover's Avatar
I never had an air shifter on my bike, but a coulpe of times i didnt slam it into 1st it would pop into neutral..
Now I dont think there is a gear selector.
zx10lover is offline
post #5 of 6 Old 04-11-2006, 08:48 AM Thread Starter
BANNED
it is going into 2nd for just a moment and it pops out --i think-- it happens so fast i dont know for sure. it didnt do it every pass though. i adjusted my kill time a little longer and it worked for the first couple of passes then it started again...
mikebar4 is offline
post #6 of 6 Old 04-12-2006, 06:42 AM
GeorgeC's Avatar
Where do you have the air valve in relation to the shift solenoid? Ideally, you want the air line from the valve to the solenoid to be as short as possible for a quicker shift. You might have to increase the kill time a pretty good bit to compensate if it's too far away.
What you're describing could also be a symptom of tranny problems. When the dogs on the gears start to wear and become rounded off, the bike will want to pop out of gear, since the dogs will slip and not let the gears engage properly. That's why you may have heard of folks getting tranny gears "cut." You could also have a slightly bent shift fork which isn't engaging the gear completely (and will only serve to also round off the dogs on the gear).
George Coffey
'05 ZX-10R (stock)
'05 Hayabusa: 8.87 @ 161mph "all motor"
GeorgeC is offline
Cheap gear postion switch indicator lespaul66 Performance and Tech 153 04-20-2006 04:27 PM
Ver 2: Cheap Gear Position Indicator fastbikesrule Performance and Tech 43 04-01-2006 11:48 AM
Throttle position, gear, and power AraTidwell The ZX-10R 3 06-19-2005 12:37 PM
Gear indicator miykl The ZX-10R 15 05-28-2004 08:34 PM
RedElk's ZX10R Ride and Adventure review swft The ZX-10R 11 03-11-2004 01:24 PM
