Help W/Installing Catalyst Plastics 04 ZX10 - Kawasaki ZX-10R.net
post #1 of 13 Old 08-16-2006, 12:53 PM Thread Starter
socal's Avatar
How do you install a Catalyst supersport tail on a '04 ZX10?? Order of install, ie seat first followed by the tail or vice versa?? Where to secure the front of the tail?? etc. Thanks!!
WSMC #644
socal is offline
post #2 of 13 Old 08-16-2006, 02:18 PM
CountDokoo's Avatar
seat first, then tail. tail mounts primarily on 2 spots beneath the seat and i believe it comes marked for drilling. I've successfully used DZUS quick release bolts on this part but it's tricky requiring you to mount the quick release holder ONTO the painted surface of the tailboard. (cushion with cloth or something) The quick release bolt goes from underneath...
personally i think 2 mounting pts is a little too flimsy for me and so I've drilled out the 4 holes used for the stock fender and with the help of 8mm rubber nuts (those windscreen rubber holders with nuts in them) i've managed to secure the rear of the tail to the subframe (u gotta drill the subframe too at the part where you used to pass bolts thru to fit them) via long bolts.
and when you're done with everything, you need to find at least a 2cm spacer to stuff into the REAR 2 holes before bolting them in as there's a big allowance inside between the subframe/battery tray and the tail unit.
CountDokoo is offline
post #3 of 13 Old 08-16-2006, 02:23 PM
Hillbillie Mod
hillcountry10r's Avatar
Images: 31
https://www.zx-10r.net/forum/showthread.php?t=7577
James 3:7,8
hillcountry10r is offline
post #4 of 13 Old 08-16-2006, 02:50 PM Thread Starter
socal's Avatar
Originally Posted by hillcountry10r
I looked @ the HotBodies instruction post. The Catalyst Racing Composites, however, are installed differently. Specifically, the Catalyst tail section is not marked for drilling @ the point where the seat is bolted. The tail section eyelets are located under the seat and inaccessible.
WSMC #644
socal is offline
post #5 of 13 Old 08-16-2006, 02:52 PM Thread Starter
socal's Avatar
Thanks for the reply. Just want to confirm that we are talking about installing Catalyst Plastics...
WSMC #644
socal is offline
post #6 of 13 Old 08-16-2006, 02:53 PM
CountDokoo's Avatar
The Catalyst Racing Composite tail comes marked for drilling in the front just beneath the edge of your seat's rear.
They're also marked for drilling underneath the tail specifically for fender eliminator mounting.
post #7 of 13 Old 08-16-2006, 03:12 PM
Hillbillie Mod
Images: 31
well seems like in order to mount the seat, youre gonna have to drill a hole in any tail, no?
James 3:7,8
post #8 of 13 Old 08-16-2006, 04:02 PM Thread Starter
socal's Avatar
My thoughts exactly. But here is a photo fr Catalysts web site of the tail installed:
WSMC #644
socal is offline
post #9 of 13 Old 08-16-2006, 08:45 PM
Just did this last month with the Catalyst bodywork. Came out very nice. Just drilled the two forward holes that are under the rear of the seat, and bolted it loosely into place.
Then, drilled very tiny holes at the rear (underneath) mounting points and looked through them to sight the holes. Then enlarged them enough to fit two bolts (same as the stock upper bolts), using a Unibit.
Got a couple clip nuts and installed them over the subframe tabs so that I could install the bolts from underneath.
BTW, it helps a lot to remove the brackets on top of the subframe that mount the stock tailsection, as well as the latch mechanism. Makes it much easier to slide the tailsection on.
To get the seat to mount, I used my die-grinder to notch the front of the tail in order to be able to install the seat after the tail is in place.
I can take pics if it would help. Lemme know.
CanyonCarver is offline
post #10 of 13 Old 08-16-2006, 09:23 PM Thread Starter
socal's Avatar
Pics would be great!
WSMC #644
socal is offline
FS: 2006 ZX-10r Race plastics !! Catalyst Composites**SOLD** teebo7 Parts, Gear and Accessories 6 09-05-2006 10:20 PM
Installing 520 kit, how to sumjoeguy Performance and Tech 4 06-05-2006 03:19 PM
04 plastics fit on a 05 zx10-R ?? guzmanx The ZX-10R 6 04-05-2006 06:20 PM
Catalyst BodyWork hillcountry10r The ZX-10R 2 04-12-2005 09:58 AM
need help installing 16t zexxx04 Performance and Tech 12 01-03-2005 10:28 PM
