Head shake at the last half of the 1/4 - Kawasaki ZX-10R.net
post #1 of 6 Old 05-17-2011, 12:00 AM Thread Starter
gomer's Avatar
The last two times I went to the strip I started to get a mean head shake.
I can make it through first and second just fine but through 3rd and 4th I have to let off because it becomes scary. I Got the front wheel checked for balanced and messed with tire pressures. If I turn the steering damper to a stiffer setting it just makes it worse. My next place to look was if the back wheel was was cocked a little more forward on one side dude to me putting the tentioners in different spots.
Any suggestions?
05 Titanium
gomer is offline
post #2 of 6 Old 05-17-2011, 12:40 AM
Dont mess wit White Ninja
abzx10r's Avatar
Suspension setup, forks moved in the trees, pressure,balance,axle. check everything!
abzx10r is offline
post #3 of 6 Old 05-22-2011, 07:45 PM
Did this start all of a sudden or did you make any changes and then it started?
Gixx1300R is offline
post #4 of 6 Old 05-22-2011, 09:38 PM
strkd50's Avatar
It started all of a sudden this year. Ran good for him all of last season.
2012 ZX-14R
#228
strkd50 is offline
post #5 of 6 Old 05-23-2011, 04:07 AM
or10r's Avatar
I would double check your fork settings to make sure they are indentical on both sides. Wouldnt hurt to loosen your pinch bolts and follow the procedure for re-installing the front wheel. If one of your forks is binding that should take care of it.
or10r is offline
post #6 of 6 Old 05-23-2011, 06:17 AM Thread Starter
gomer's Avatar
I did take the front wheel off and put it back on. I went on Saturday and noticed it again but if I take my butt off of my seat and lean all the way on my tank it wont really do it. It is making me mad and I dont want to keep going to the track if I just wobble the whole time.
05 Titanium
gomer is offline
head shake.... ZX10Hef The ZX-10R 22 10-01-2009 10:45 PM
The Head Shake! kawasloppy The ZX-10R 13 01-03-2008 10:57 AM
Head Shake!!!! jarhead05 The ZX-10R 52 01-17-2006 08:25 PM
Head shake GARSZX10R Performance and Tech 26 12-07-2004 02:42 PM
Head shake FrEteGi The ZX-10R 15 04-09-2004 08:13 PM
