Gen4 Kit ECU Shift Indicator on Dash - Kawasaki ZX-10R.net
 2Likes
  • 1 Post By mattinrsm
post #1 of 10 Old 04-23-2019, 02:52 PM Thread Starter
mattinrsm's Avatar
Hello Everyone,
I have a Gen4 with the Kit ECU and harness. The shift light is set to around 12,500 rpm in the software, but nothing happens when I run past that point. The tach and everything works fine otherwise. Do I need to select the shift-up indicator mode on the dash, or do something else to get the dash to blink when I want? Any help is appreciated.
Matt
mattinrsm is offline
post #2 of 10 Old 04-24-2019, 12:01 AM
michael4012's Avatar
12.500 on the dash is in reality about 11.500 in the ECU typically the dash reads about 1000-1200 RPM higher so if your revving past 13.500 on the dash and getting no shift light then maybe you have a problem.
michael4012 is offline
post #3 of 10 Old 04-24-2019, 09:16 AM Thread Starter
mattinrsm's Avatar
If the dash is really that far off, then maybe. I was shifting around 13,500 indicated, sometimes around 13,750. Sometimes 13,000 depending on the corner, etc. I can adjust it in the ECU easy enough, it's just not as easy to check when not at the track.
post #4 of 10 Old 04-24-2019, 10:24 AM
Well to be safe temporarily drop the shift to 5000-6000 or something that way you can confirm that the shift light will in fact work once you've confirmed it you can set it where you want.
post #5 of 10 Old 04-24-2019, 01:39 PM
is it enabled? IIRC You had to set a flag to enable it. If you enable launch control and rev the motor in 1st gear does the shift light start blinking? That would confirm the circuit is working.
The light is pretty darn simple. It just plugged in and worked for me based on my kit ecu settings.
I assume you also have the kit harness...
AFM #705 | youtube | instagram | facebook
Please give some love to my 2019 Sponsors!
Daredevil Motorsports | Amsoil | SPY Optic | GoPro
JayBoCC2 is offline
post #6 of 10 Old 04-24-2019, 02:44 PM Thread Starter
mattinrsm's Avatar
Yes, I have the kit harness. I don't see any switch to enable it. There is only a cal table called Shift Lamp Rev. Launch Control is turned on but I haven't tried it yet.
If michael4012 is right, it would make sense that I'm not seeing it work. My shift rpms are set at - 12300, 12500, 12600, 12800, 13000, and I'm really only looking at the tach on the 3-6 shifts.
Everything else works fine on the display, so I'll try dropping the table values and see what happens.
post #7 of 10 Old 04-25-2019, 08:25 AM
Carlos76's Avatar
Matt, maybe you overlooked that shift light is a separate lamp that connects to kit harness?
Gen4 race: high spec.
Suzuki GSX1300R Hayabusa 2013: stock.
Kawasaki KX450F 2016: love it.
Carlos76 is offline
post #8 of 10 Old 04-25-2019, 09:25 AM Thread Starter
mattinrsm's Avatar
My understanding was that the dash tachometer would work with the Kit ECU shift lamp function. So your saying that with the kit ECU the shift lamp capability of the tachometer is removed, and a separate external shift light must be installed, correct? This is from the manual:
Shift indicator setting
􀁺 The blinking rev of the shift indicator on the meter or externally-connected shift indicator can be
set by the Shift Lamp Rev by each gear.
􀁺 The blinking rev of the shift indicator cannot be set by the meter switch when the racing ECU is
installed.
So, I thought it was an either / or choice. I could use the tach, or a separate light. I appreciate your thoughts and response.
michael4012 likes this.
post #9 of 10 Old 04-26-2019, 12:59 PM
installed.
OH...
so the KIT ECU Shift light settings require the external extra shift light (green plug by dash connector on kit harness). Its a little blue light that flashes/comes on when you're in launch control mode or you hit your shift RPM.
JayBoCC2 is offline
post #10 of 10 Old 04-29-2019, 11:03 AM Thread Starter
mattinrsm's Avatar
Alright, now I get it. Thanks for the information and pictures.. That's a bummer that I need to purchase an additional shift light, but not a big deal in the grand scheme of things.
Shift light RPM indicator issue 2016+ kit ecu Tsmathers33 Performance and Tech 4 07-11-2018 03:25 PM
anyone ever used a bazzaz shift sensor with the Kit ecu? J_fuggin_t Track 8 06-02-2017 08:42 AM
Gear indicator or at least 6th gear indicator? RememberTheMallamo The ZX-10R 21 06-16-2012 08:49 PM
06 ZX10R Dash Indicator light. *JD* The ZX-10R 24 10-06-2008 09:34 AM
