Gen 3 LSR and HP Gain Advice - Kawasaki ZX-10R.net
post #1 of 6 Old 05-10-2015, 10:38 PM Thread Starter
Hi Guys,
I'm planning on taking my 2008 ZX-10R to the salt flats this year to see how fast we can go. As a result, I'd like to squeeze more HP out of the bike... as much as I can without turbo / nitrous for the time being.
It's currently basically stock. I have an LOR slip-on and a juicebox on it.
Based on some of the other great threads I've read, here's the list of items I'm planning on doing. I'd love to get your input and feedback:
  • Full Exhaust
    Woolich Racing ECU Package
    Race Intake Camshaft
    Race Exhaust Camshaft
    Degree Cams
    .45mm head gasket
    Dyno Tune
I'm also planning on doing some suspension / body work to improve things:
  • BT-003 Tires
    LSR Front Fender
    Lowering Link
    Lower Seat
Let me know what you think and if you have other suggestions on how to improve things. Thanks for your help / input!
Cheers
dutcheez is offline
post #2 of 6 Old 05-10-2015, 11:10 PM
Teeks's Avatar
Those sound like really good plans. The only other things I can think of don't really involve hp. Just since you said its stock, you can remove weight, reduce rolling resistance with lighter chains, sprockets, wheels, and high end bearings.
Originally Posted by -Op- View Post
Unless Scout says dont do it. Then, really, just do it.
Originally Posted by or10r View Post
I know its blistering fast but you cant outrun ugly.
Teeks is offline
post #3 of 6 Old 05-11-2015, 08:32 AM
SkyDork's Avatar
Salt flats, huh? Looking to join the 200MPH club!!! Woohoo!
Well, the mods you got listed are a good start. But you're still only looking at minor HP improvements getting close to the 180hp mark on a Gen 3 with all that stuff. Maybe a bit more. IMO, you need to be concentrating more on aerodynamics than Hp improvements. If you're wanting to go faster, you need less drag.
#WordCrimes
SkyDork is offline
post #4 of 6 Old 05-11-2015, 09:30 AM
SpazOnaZX's Avatar
SpazOnaZX is offline
post #5 of 6 Old 05-11-2015, 11:29 AM Thread Starter
Good point. I plan on removing the front rotor and brake to reduce resistance there. Do you think a lighter chain and sprockets will do that much? I've talked to a few guys there that also run high end bearings... might be worth it if it doesn't cost too much.
dutcheez is offline
post #6 of 6 Old 05-11-2015, 11:43 AM Thread Starter
I agree, I don't see us reaching 200 mph with this setup. We actually went to the salt flats a few years ago with this bike pretty much stock: slip-on exhaust, K&N air filter, 10" rear extension and were a little surprised when we only managed 164 mph Turns out that 10" extension wasn't such a good idea. It might provide more stability but without weight on the rear wheel on a salt bed, we lost a lot of traction.
You're right, aerodynamics will do a lot more. I've looked at Airtech: LANDSPEED, LAND SPEED RACING, SALT RACER, BONNEVILLE, EL MIRAGE, FAIRING, SEAT, FENDER, SCTA, CESSNA, WHEEL PANTS COVER, 170,172,175 , they have some popular streamlining fairings including the "Charlie Toy". I'm hoping to keep the budget within reason though and looking at that setup... that's another $$. But, if it can be done cheaper, I'm all ears. Do the race fairings such as hotbodies provide any additional streamlining?
Also, would shorter velocity stacks have any effect? Replacing the inside ones with outside ones?
dutcheez is offline
Gen 1 questions, need advice/help stikettezx10 The ZX-10R 4 06-24-2014 03:55 AM
Advice on issue with gen 3 Kawawog Performance and Tech 0 09-24-2012 04:37 AM
Gen 4: Ricky Gadson's LSR bike garth285 Race and Stunt 28 08-15-2011 05:47 PM
the bemer takes the 1k LSR filthy phil General Motorcycle Discussions 21 09-21-2010 01:53 AM
