Gearing/Suspension advice - Kawasaki ZX-10R.net
post #1 of 2 Old 03-11-2015, 05:16 PM Thread Starter
Blue08's Avatar
Location: Mentor on the Lake, Ohio/Broke at a dragstrip
What's up guys wasn't sure to post this here or in suspension section but I figured here bc it's for drag racing. I have an 08 zx10r sitting right about 64" boltons, full exhaust and geting it tuned in 89 and mr12. Brocks clutxh mod and drag pack are in the mail. Right now I'm -1+4 and lowered about 2" in front also strapped and lowered about 3 in the rear. Use the bike mostly for 1/4 mile and I'm about 170 suited. I've tried to read about the visa shock but I dont know jack about suspension and setting it up. Will I benifit at all from the visa shock or will I be able to mess with mine to get it set up right for me? I'm trying to avoid dropping a bunch of money in an aftermarket shock.
65, pos
8.67 @ 154mph
Blue08 is offline
post #2 of 2 Old 03-11-2015, 05:35 PM
TechX's Avatar
Your stock shock should work ok. Just run it full soft to start with and then make some small adjustments as needed. With your long swingarm you should have very little wheelie problems but you want the bike to squat on launch and not have the shock rebound to quickly as that might give you some wheel hop. So a good starting point is compression full soft and rebound at full soft and then adjust from there based on what you feel the bike is doing on launch.
TechX is offline
Gen 4: Need some suspension advice. Turbodc2 General Motorcycle Discussions 3 09-22-2014 07:01 PM
Gen 4: Need some suspension advice. Turbodc2 The ZX-10R 8 09-14-2014 10:02 PM
gearing advice my10r The ZX-10R 4 05-05-2013 05:26 PM
Gen 1: Need gearing advice for a street race.. Slow10r Race and Stunt 54 03-31-2013 10:29 PM
Suspension setup advice magarac Performance and Tech 10 09-10-2006 06:10 AM
