Gear Change? - Kawasaki ZX-10R.net
post #1 of 39 Old 07-08-2006, 04:28 PM Thread Starter
Gear Change?
Has anyone ran -2ft and +2rear on a stock wheelbase bike? If so, how was is it? What does everyone think about that ratio?
BryanB is offline
post #2 of 39 Old 07-08-2006, 04:40 PM
Ruthless Racing's Avatar
Images: 9
I have -2 up front and bought a +2 rear from a guy off the board to try it. I put the 41 on and road it down the road and came back and put the 39 right back on. IMO way to much gear for stock wheelbase bike. I have a 15 and 16 and depending on the track I swap between the two and keep the stock rear.
Kenny Poppell
AMA Dragbike SuperSport #1000
2007 AMA Dragbike 1000SS National Champion
2007 1000SS 1/8th ET Record Holder 5.967
Best 1/[email protected] Best 1/[email protected] Stock Wheelbase
Special Thanks:
Performance Psycle
Richies Tires
http://www.XXXRacingFuel.com
http://www.SuperbikeSpecialties.com
http://www.Tsukigi.com
http://www.CycleConceptsRacing.com
http://www.myspace.com/ruthlessracing1
Ruthless Racing is offline
post #3 of 39 Old 07-08-2006, 04:47 PM Thread Starter
right now im -1 and +2 so im inbetween your two gears, i like it, it just seems that first is just so long
BryanB is offline
post #4 of 39 Old 07-08-2006, 04:56 PM
Images: 9
39/15= 2.60
41/16= 2.56
41/15= 2.73
If you have the stock rear, buy a 15 and try that gearing out. With a stock motor, stock wheelbase bike IMO 15/39 is the gear.
Kenny Poppell
Special Thanks:
Performance Psycle
Richies Tires
post #5 of 39 Old 07-08-2006, 05:08 PM Thread Starter
Well, my stock gearing was 17/40 and right now im 16/42. So I'm at 2.625. Close to what you are recommending. So you think im fine or should change to 15/39?
BryanB is offline
post #6 of 39 Old 07-08-2006, 05:21 PM
Images: 9
I think that is a good ratio. Sorry didn't know you had an 06.
Kenny Poppell
Special Thanks:
Performance Psycle
Richies Tires
post #7 of 39 Old 07-08-2006, 05:24 PM
Big Daddy's Avatar
Images: 38
leave it. IMO the 15t is way to extreme of a radius to subject the chain to i don't care if its strickly drag or not its too tight.
Since you have an 06 W/ 17/40 as stock the 16/42 is pretty extreme as well but acceptable since you changed both sprockets.
Big Daddy is offline
post #8 of 39 Old 07-08-2006, 05:24 PM
great gearing if you dont plan to pass 160mph and love to wheelie..
deezuhl is offline
post #9 of 39 Old 07-08-2006, 08:00 PM
bragg10r's Avatar
I have -2 in the front with the stock in the rear. I have passed 160 with this gearing. I top out at around 172mph with that gearing. I think that is fast enough, not only that but i'll get there faster then you!!!!!!
p.s. I know it was 172 because I have the Speedo Healer!!!!!!
"Best" (Time Slip Proof) Run so far :
60ft:1.7
330ft: 4.5
1/8: 6.7 @ 113mph
1/4: 10.2 @ 142mph
bragg10r is offline
post #10 of 39 Old 07-08-2006, 08:21 PM
guess what your healer isnt as acurate as GPS.. the loss is not linear so the healer isnt 100% accurate it just gets you closer than stock.. -2 teeth looses 22mph from 186.. makes it 164mph.. then figure +2 in the rear is is about 8mph gives you a good 156mph..
PS.. you will get to 164 faster than me but we dont consider that racing at that speed. 600's can go 164mph..
deezuhl is offline
TRE USERS..Gear Indicator…bad NEWS bluedevil Performance and Tech 29 10-23-2006 03:30 PM
My 06 Gear Shift Bolt Fell Out!!! mumbles6 The ZX-10R 7 05-13-2006 02:39 PM
How to change your own oil & filter... El Diablo The ZX-10R 1 02-07-2005 11:28 PM
How to change your own oil & filter... El Diablo How To... 1 02-07-2005 11:28 PM
RedElk's ZX10R Ride and Adventure review swft The ZX-10R 11 03-11-2004 01:24 PM
