Front suspension - Kawasaki ZX-10R.net
post #1 of 16 Old 03-13-2012, 10:59 PM Thread Starter
Does not drive into smoke
El Zilcho's Avatar
Front suspension
Next question...
I have a 2005 636 for track. What is the usual procedure for upgrading the front suspension? I looked for Ohlins forks, but what I found on the Ohlins website was only cartridges and springs.
Does that mean that the way to upgrade forks is to replace some of the fork components with aftermarket parts, or should I keep looking for a complete set of forks?
I mentioned that it's 636, because the upgrade may depend on the actual bike model.
El Zilcho is offline
post #2 of 16 Old 03-13-2012, 11:48 PM
Tee's Kawa55's Avatar
You can give RaceTech a call or look on their website. They can take care of you.
DDM Tuning HID lights| Sportech Windscreen| ASV shorty levers| Driven D3 grips| Evotech 1/4 turn gas cap| LSL sliders| Woodcraft case covers| PCV with custom map| BMC race filter| secondaries removed| EK 525 red chain| Vortex rearsets| M4 Slayer exhaust| PSR chain adjusters| Speigler brake lines| custom front and rear seat| Pro bolt aluminum bolt kit| Hellrazor servo eliminator
Tee's Kawa55 is offline
post #3 of 16 Old 03-14-2012, 12:34 AM
flthy1's Avatar
^^ +1! Crazy what a difference just some valve and springs will make!
flthy1 is offline
post #4 of 16 Old 03-14-2012, 09:59 AM
It depends on what you want to do with the bike. You can do a 20mm kit which replace some of valving in the forks. I run GP suspension 25 mm kit which replaces the entire guts of the forks ohlins has the same kit. Gives you way more adjustment. It basically makes your forks equievelment to ohlins R/T forks. Most racer use the 25mm kit because it's supersport legal. Sorry I can't be more technical I'm just the dummy that sits on the bike my supension guy adjusts and builds according to my input. :)
expatracer is offline
post #5 of 16 Old 03-14-2012, 10:11 AM Thread Starter
El Zilcho's Avatar
I was told that the stock suspension on the 636 is, hmm.. "lacking". In particular the rear shock. I ordered an Ohlins shock, but I couldn't find any simple solution for the front.
What I want is to get my bike up to a decent level for track riding. It's a dedicated track bike, so I'm not too worried about adding "race-only" components. I'm planning to do as many track days as I can, develop techinque, speed, etc., etc. The suspension was the first thing that was suggested (or even "recommended") to me by advanced riders, so I want to take care of it next.
I used P1 Racing on the track, but other than that, I guess I am my suspension guy.. lol
post #6 of 16 Old 03-14-2012, 10:21 AM
All show and all go 10r
JLG0987's Avatar
I had my 05 636 forks redone and they are great. Cartridges only replace the internals. If you can get them for a good deal get them. I had mine revalved, re sprung, ohlins piston kit and a couple of other little things and they are great. Not as good as R/T but considering it was half the price is more than half as good as far as feel.
JLG0987 is offline
post #7 of 16 Old 03-14-2012, 11:06 AM
bird_dog0347's Avatar
Images: 11
Just doing internals is fine. I have the stock fork externals and traxxion dynamics AK-20's for the full cartridge internals. They are a huge upgrade...
04 10R - My late brother's bike, will keep forever
03 636 - Track bike build in progress
92 Foxbody coupe, 5.0, 5spd.
FASTEST CHICKEN IN THE SOUTH!
bird_dog0347 is offline
post #8 of 16 Old 03-14-2012, 11:13 AM
caboose's Avatar
Send a message via MSN to caboose
Full ohlins forks are a waste of money. The R&T forks use a 25mm cartridge kit so you can save money and just get a 25mm cartridge kit for your specific bike.
If you don't want to get that spendy you can get a set of Ohlins prings and a piston kit for about $400. Or if you're lucky, the OEM springs will be the right spring rate for you and you can just get a Piston kit for a bit over $200.
2010 10R Superbike
caboose is offline
post #9 of 16 Old 03-14-2012, 11:33 AM Thread Starter
El Zilcho's Avatar
I looked at the prices and the 25mm kits are nearly 2x as expensive as 30mm kits, and the 30mm kits are supposedly better (?). Still, it was around $1000 even for the 30mm kit. Yeah, the $400 solution would probably be just fine for me. I'm not even sure what the shortcomings of the stock forks are.
I guess I'll ask the suspension guys on the track exactly what parts they recommend (like what length springs, etc.). I'm a bit wary of buying and replacing parts in the forks, since I don't quite understand how all the parameters influence the final performance...
post #10 of 16 Old 03-14-2012, 11:41 AM Thread Starter
El Zilcho's Avatar
I found their spring rate calculator and they even have something close to what the optimal rate was. Are their springs good? How about their valve kits?
06 zx10r front suspension help rumpelstiltskin Performance and Tech 2 09-03-2011 09:04 PM
Gen 3: Front suspension craig_sez Parts, Gear and Accessories 3 03-29-2011 12:59 PM
WTB Very bad...Race front suspension 04/05 ZX-10R tibofew Wanted: Buy or Trade 0 02-22-2009 12:42 AM
05 Front Suspension 05Ti10 Performance and Tech 9 06-14-2007 10:56 PM
Front Suspension kawiiiiii Performance and Tech 2 06-10-2007 06:16 PM
