Front End Strap - Kawasaki ZX-10R.net
post #1 of 3 Old 04-03-2008, 05:47 PM Thread Starter
OneSLOW10's Avatar
Send a message via AIM to OneSLOW10
Front End Strap
Awhile ago I ordered a front end strap for the Beast. Since then I noticed that some companies also sell Caliper bracket adapters with the strap. Do I need to get the Bracket Adapters or will the straps work fine. The look similar to these.
http://cgi.ebay.com/ebaymotors/KAWAS...WDVWQQtcZphoto
2005 PMR. Full Ti Evo 2, BMC Race, V-Stacks, PC3, IG Module, DJ QS (not installed), 1/5th throw (not installed), -1 +2 with Gold RK Chain, Speedo Healer V4, Removed 2ndaries, Red GiPro, Pilot Powers, Dual H.I.D.s, Brocks brackets and strap, Rear 2" Muzzy Drop, Vortex Rearsets, Scotts Damper, 2 HyperPro Dampers, Puig DB, ASV Levers, Titax Levers, Pazzo Levers, Kill switch (made to look like it's mounted), CA front/rear lights and a owner who adores her...
OneSLOW10 is offline
post #2 of 3 Old 04-03-2008, 05:54 PM
fastkawi739's Avatar
I ran without the brackets but I had to grind and bend the mounts that attach to the caliper so they would mount flush behind the caliper bolts. I did end up buying the mounts and doing it right. It will work either way but I feel better with the brackets on mine.
7.5" extensions($300), 6 up rear sprocket(free), front straps($20), lowering links($60), removed slipper($200), shinko u-soft rear($165),Yoshi Slip ons ($300) 9.84 @ 143 w/fat boy(230lbs) = priceless.
fastkawi739 is offline
post #3 of 3 Old 04-03-2008, 06:07 PM
MIA Ex-Mod
Tread70's Avatar
I would get the brackets if'n you want to do it right.
Tread
2004 PBO zx10-r pazzo, seat cowl, yoshi Ti TRS bolt on, PC3, Speedo-Healer, Hyperpro, Braided lines, 16-40, Sato sets, ZG dark screen, and more.
Tread70 is offline
Installing a front end strap. busaforhire Performance and Tech 40 07-27-2007 12:28 PM
front strap question JodyH Performance and Tech 5 03-16-2006 08:36 AM
Front lowering strap w/ brackets Tread70 Parts, Gear and Accessories 5 11-09-2005 09:42 AM
Installing a front end strap. busaforhire How To... 1 08-23-2005 09:49 AM
Too Strap or not Too strap???? bluedevil Race and Stunt 7 08-19-2005 07:08 AM
