Gen 4: 2011-2015 Front axle clamp (pinch) bolts safety wire - Kawasaki ZX-10R.net
post #1 of 11 Old 04-27-2013, 04:51 PM Thread Starter
brilliantspeed's Avatar
Need advice on how to safety wire the front axle clamp bolts (A). I drilled holes, but the bolts are recessed way into the forks and once torqued, it's difficult to find space to run the safety wire through. Ideas?
brilliantspeed is offline
post #2 of 11 Old 04-28-2013, 01:30 PM Thread Starter
No response? Does anyone make pre-drilled clamp bolts for this bike?
post #3 of 11 Old 04-30-2013, 02:52 AM
Nutter34's Avatar
My only thought... Drill the holes about where the 'A' symbols are. There may be enough to get wire through for a locking. Yes, the locking won't be correct in the true sense, but it will stop the bolt from rotating around...
PS: What size lockwire you using? 0.025" or 0.032"?
"You are only young once, but you can stay immature indefinitely."
Nutter34 is offline
post #4 of 11 Old 04-30-2013, 05:43 AM
greenman43's Avatar
Images: 33
Perhaps consider longer bolts, and drill the holes at the other end where they'd come out of the fork legs.
Cheers,
Brian
Do not walk behind me, for I may not be leading.
Do not walk in front of me, for I may not follow.
Do not walk alongside me, for the path may be narrow.
Just piss off and leave me alone.
greenman43 is online now
post #5 of 11 Old 04-30-2013, 08:10 AM Thread Starter
Cheers,
Brian
So this is an interesting thought and one I've been considering. Need to look up some info or pics on how best to safety wire at the other end. Another thought I had was to replace the bolts with hex/flange heads...those that don't go through.
Thanks to all for input. Much appreciated.
post #6 of 11 Old 05-01-2013, 06:47 AM
greenman43's Avatar
Images: 33
Cheers mate, best of luck :)
post #7 of 11 Old 05-01-2013, 10:28 AM
JDSZX10R o8's Avatar
It can be done using the stock bolts. Tighten them up. Mark the bottoms, as there is more clearance from the fork body. Drill them out & wola :-)
Like Nutter said above.
Axle bolt. Hmmm. Mine is not done but it passes inspection.
PRESENT
11 ZX10R Track/Race
08 ZX10R - Track/Race (was a Ins write-off)
PLUS a few more.
PAST
Way to many to list.
JDSZX10R o8 is offline
post #8 of 11 Old 05-01-2013, 10:49 AM
kman0066's Avatar
For the axle bolt, you can drill through at an angle, like this picture below. This is what I did to mine. Picture is from internet though:
For the pinch bolts, I just curl the safety wire into a hook shape, and then hook the wire through the holes in the bolts. Also, it helps to drill multiple holes in the bolt so that you have options when you go to wire it up. If you put 2 holes, 180 degrees from each other, you should end up with a convenient hole for each bolt.
It doesn't have to be perfect, and you don't have to have the wire going all the way through the bolt. If you just go through 1 of the holes in each bolt, it will be fine, they won't go anywhere.
WERA Expert #43
2012 WERA National Challenge Series Open Superstock Novice Champion
http://maps.wera.com/racers/racerpro...30532136163864
COMET RACING LEATHERS
2011 ZX-10R Race bike (Vortex, Silkolene, Leatt, Yoshimura, BRIDGESTONE)
2013 ZX-6R 636 Race bike
2008 Ducati Hypermotard 1100s
kman0066 is offline
post #9 of 11 Old 05-01-2013, 01:28 PM Thread Starter
Trying to figure out the best way to drill the axle at an angle. Did you drill with the axle in place (maybe loosen have it stick out a bit) or did you completely remove the axle?
post #10 of 11 Old 05-01-2013, 01:52 PM
kman0066's Avatar
I did it with the axle in place. The metal is super soft (surprisingly), so a good punch will get you started well enough, then just be careful with the angle so you don't break through the corner.
WERA Expert #43
kman0066 is offline
Safety wire question afskypilot Race and Stunt 10 01-07-2008 11:21 AM
Safety Wire fpzx10 Vendors deals 7 10-06-2007 12:22 AM
What to Safety Wire IcePick06 Race and Stunt 9 02-18-2006 04:59 AM
to remove front axle clamp bolt kuzco The ZX-10R 10 04-01-2005 12:28 AM
Safety wire Zxrider The ZX-10R 0 03-14-2005 12:42 PM
