Estoril Preview - Kawasaki ZX-10R.net
post #1 of 13 Old 04-11-2008, 02:51 PM Thread Starter
06BLK10R's Avatar
Images: 49
Send a message via AIM to 06BLK10R Send a message via Yahoo to 06BLK10R
Estoril Preview
Colin Edwards & James Toesland are going to the Pneumatic Valve Engine will see how they Do with those babies.
http://moto-racing.speedtv.com/artic...toril-preview/
LIFE IS 2 SHORT SO LIVE IT TO YOUR FULLEST........
2006 BLACK ZX 10R
Akra CF Exhst,stomp grip,Attack rear sets, CZ Anodized Blk wheels,Power bronze rear hugger,Pwr Cmdr,Hel braided Brake lines,Puig sliders,Puig Windscreen,Kawi seat cowl,520 Chain Conversion.
2001 GSXR 600 RACE BIKE
www.myspace.com/ninjapat66
http://bloxstarzlifestyle.com
06BLK10R is offline
post #2 of 13 Old 04-11-2008, 02:54 PM
or10r's Avatar
Is this new technology? Are they just doing R&D or do they expect to be competative?
or10r is offline
post #3 of 13 Old 04-11-2008, 03:09 PM Thread Starter
06BLK10R's Avatar
Images: 49
Possibly all the above,Rossi & his teammate allready are running the engine if not mistaken.Know the satelite team is getting to try it out.
2006 BLACK ZX 10R
06BLK10R is offline
post #4 of 13 Old 04-11-2008, 03:11 PM
or10r's Avatar
Do you have any idea how it works?
or10r is offline
post #5 of 13 Old 04-11-2008, 04:12 PM Thread Starter
06BLK10R's Avatar
Images: 49
Pneumatic valve springs are metal bellows filled with compressed air[1] occupying roughly the same space of metal springs used to close valves in high-speed internal combustion engines.
Reducing the number of moving parts that can fail is good engineering. Racing engines often failed at high speeds because mechanical springs were unable to close valves fast enough, leading to engine failure when pistons struck incompletely closed valves. Renault's innovation was to replace steel springs with light weight compressed air bellows that could respond more quickly and reduce the possibility of valve crashes, other than from leaking bellows. Additionally, the amount of seat tension required to keep a coil sprung valve under control results in peak lift loading drastically higher, with added stress to the entire valvetrain as a result. Pneumatic systems, sharing a common reservoir of pressure retain a more static level of force, controlling the valve effectively, without any attendant peak lift load increase. To avoid bellows failures, air springs are replaced often
2006 BLACK ZX 10R
06BLK10R is offline
post #6 of 13 Old 04-11-2008, 04:43 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
Where'd you copy and paste this from?
F-1 cars have been using the technology for years now, it alows the engines to achieve stratospheric rpm, F-1 cars run close to 20,000 RPM, from a V8.
Early systems were plaqed with unreliability (leaking bellows)but its pretty proven technology now.
9R to 10R is offline
post #7 of 13 Old 04-11-2008, 07:31 PM
Andy's Avatar
Images: 25
I wonder why it's just now getting into MotoGP technology. Is there any power advantages to this design or is it strictly for reliability?
Andy is offline
post #8 of 13 Old 04-11-2008, 08:28 PM
or10r's Avatar
I am wondering that as well Andy, I also wander if there are any possibilities of the same "floating" with the bellows valve as there are with standard valves.
or10r is offline
post #9 of 13 Old 04-11-2008, 09:58 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
Well, I would say there is huge gains to be had, any time you can extend the rev range of the engine out to that extreme, thats got to be huge.
post #10 of 13 Old 04-11-2008, 10:11 PM
ZX-10R_Sinner's Avatar
I thought Kawi's screamer motor already used this technology as well...
ZX-10R_Sinner is offline
Preview - Qatar Grand Prix. jasonmayer Track 5 03-18-2008 07:22 PM
Preview - Valencia. Sto Track 0 04-12-2007 02:15 PM
Estoril predictions danno46 Track 74 10-16-2006 07:20 AM
VIDEO - Ghostrider Z3 M Coupe Chase - Preview drofer The Out House 6 02-01-2006 02:06 PM
Cycle World '06 ZX10 preview zeta xray The ZX-10R 12 01-05-2006 09:42 PM
